Author Topic: Brake Wear indicators  (Read 1474 times)
Offline karl210
« on: April 03, 2013, 10:51:03 am »
Just changed the brakes on a mates car and the pads that i was given didnt have the sensors in them like the previous ones did. I changed them anyway but the indicator has come on the dash. To get rid of it do i cut the wires and insulate them so they dont touch or do i cut the wires, connect them both up so they make the circuit? Cant remember weather i need to make or break the circuit for the light to go out. thanks
« Last Edit: April 03, 2013, 10:55:08 am by karl210 »
  • -Receive: 453
Re: Brake Wear indicators
« Reply #1 on: April 03, 2013, 01:47:23 pm »
You need to connect both wires together (i.e. short them) or get someone with vcds to code it out.
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
« Reply #2 on: April 03, 2013, 02:02:20 pm »
Probably better to code them out with vcds. If you short them and then want to use the indicator in future I suppose you'd have problems.
'07 Red manual
  • -Receive: 453
« Reply #3 on: April 03, 2013, 02:06:57 pm »
I cut the wires off the old brake pad, shorted those then connected the attached plug to the indicator socket.
Offline karl210
« Reply #4 on: April 03, 2013, 04:17:25 pm »
Cheers fellas, I will short the wires out after the plug so im not damaging anything. Its not on vw so cant use vcds
