Author Topic: ABS check DTC?  (Read 1869 times)
Offline Baz300
ABS check DTC?
« on: April 15, 2013, 07:19:16 pm »
KemnayChris is having some issues with his traction control light staying on.
He had an ABS sensor replaced recenty and he has the following faults come up on VCDS.
How do I check the DTC on the ABS module?
He has also lost aircon would this just require a new unit?
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 7D
VIN: WVWZZZ1KZ4W117630   Mileage: 204590km/127126miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Cannot be reached 1100
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
7D-Aux. Heat -- Status: Malfunction 0010
Address 01: Engine        Labels: 03G-906-016-BKC.lbl
   Part No SW: 03G 906 016 B    HW: 028 101 147 8
   Component: R4 1,9L EDC G000SG  7209
   Revision: 12345678    Serial number: VWZ7Z0D9451822
   Coding: 0000071
   Shop #: WSC 00879 210 88126
   VCID: 224B2D6EFD5C0F08178
1 Fault Found:
18043 - Powertrain Data Bus
            P1635 - 000 - Missing Message from A/C Controller
             Freeze Frame:
                    RPM: 777 /min
                    Torque: 36.0 Nm
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 14.21 V
                    Bin. Bits: 00001000
                    Bin. Bits: 00000000
                    (no units): 0.0
Readiness: 0 0 0 0 0
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No: 1K0 907 379 K
   Component: ESP FRONT MK60      0103
   Coding: 0021121
   Shop #: WSC 01279 785 00200
   VCID: 3A7BF50E75CC67C82F8
1 Fault Found:
01314 - Engine Control Module
            013 - Check DTC Memory
Address 08: Auto HVAC
Cannot be reached
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-M.lbl
   Part No SW: 1K0 937 049 K    HW: 1K0 937 049 K*
   Component: Bordnetz-SG 1.0 H30 0701
   Revision: 00030000    Serial number: 00000000560430
   Coding: E4890F0600041800001400001400000000
   Shop #: WSC 00000 000 00000
   VCID: 377DEC3A46DE7AA0D06
   Subsystem 1 - Part No: 1K2 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  013  0402
   Coding: 00063445
   Shop #: WSC 00000
   Subsystem 2 - Part No: 1K0 955 559 K  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 002  0505
   Coding: 00217125
   Shop #: WSC 00000
3 Faults Found:
01493 - Bulb for Blinkers; Front Left (M5)
            012 - Electrical Fault in Circuit - Intermittent
01320 - Control Module for Climatronic (J255)
            004 - No Signal/Communication
01064 - Terminal 58d; Interior Dimming
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 A    HW: 1K0 909 605 A
   Component: 0M AIRBAG VW8   022 0500
   Revision: 04022000    Serial number: 0033FD0A4F4O
   Coding: 0012365
   Shop #: WSC 01268 785 00200
   VCID: 2A5BC54E856CD7485F8
No fault code found.
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 A    HW: 1K0 953 549 A
   Component: Lenksäulenmodul 012 0030
   Coding: 0000022
   VCID: 306FD726A3B0AD9891C
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No: 1K0 920 950 L
   Component: KOMBIINSTRUMENT VDD 3556
   Coding: 0001401
   Shop #: WSC 00879 067 57207
   VCID: 3169D222A8BAA4909E2
Address 19: CAN Gateway        Labels: 1K0-907-530-V1.clb
   Part No SW: 1K0 907 530 C    HW: 1K0 907 951
   Component: Gateway         H08 0080
   Revision: 08          Serial number: 2600104227048D
   Coding: 3D0F0B40070001
   VCID: 275D3C7A967EEA20406
1 Fault Found:
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 156
                    Reset counter: 136
                    Mileage: 198146 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 10:22:03
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO                3556
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN1.lbl
   Part No: 1K0 959 701 E
   Component: Tuersteuergeraet 09 0118
   Coding: 0000052
   Shop #: WSC 01287 785 00200
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K2 909 144 F
   Component: EPS_ZFLS Kl.2       1301
   VCID: 2F6DD45ABE8EB260886
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 S
   Component: 0W KSG              0560
   Coding: 99E802087F2D8505485AC61000
   Shop #: WSC 00879 210 55774
   VCID: 408F87E613103D1861C
   Part No: 1K0 951 605 A
   Component: LIN BACKUP HORN H01 1201
   Part No: 1K0 907 719
   Component: Neigungssensor  003 0003
   Part No: 1K0 951 177
   Component: Innenraumueberw.004 0101
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN1.lbl
   Part No: 1K0 959 702 E
   Coding: 0000052
Address 56: Radio        Labels: 1K0-035-1xx-56.lbl
   Part No: 1K0 035 186 J
   Component: Radio BNO           0016
   Coding: 0040400
   VCID: 2D51CE52B482C070BAA
Address 7D: Aux. Heat        Labels: 1K0-963-235.lbl
   Part No SW: 1K0 963 235 D    HW: 1K0 963 235 D
   Component: PTC-Element         0404
   Revision: 00700000    Serial number:
   VCID: 2C57C3568F98C978AD4
1 Fault Found:
Offline Kemnaychris
Re: ABS check DTC?
« Reply #1 on: April 27, 2013, 12:24:05 pm »
Anyone know how to resolve this the ESP light is doing my head in lol
2005 blue gray 140 gt tdi
