Author Topic: question about pcv  (Read 901 times)
Offline karl210
question about pcv
« on: April 23, 2013, 09:22:21 am »
Ive just noticed when i pull out my dipstick with the engine running it doesnt run rough atall it just keeps ticking over nicely. When i pull my oil cap off there seems to be some pressure and i can see a bit of smoke bellowing out. Now a while ago i removed the pipe between the pcv and the inlet manifold and blocked it off. Would this explain why my car doesnt run rough when i pull the dipstick? is there a vac leak elsewhere? could the rear vale be knackered? thanks
Offline andrewparker
  • -Given: 32
  • -Receive: 78
Re: question about pcv
« Reply #1 on: April 23, 2013, 09:35:08 am »
Does the car idle smoothly?
Offline karl210
« Reply #2 on: April 23, 2013, 09:46:56 am »
yeah it idles as it should. I notice there is the occasional gurgling/nocking sound from the induction kit which when i do pull the dipstick it goes constant but there is no change to the idle or rocking of the engine whatsoever
