Author Topic: RNS 510 Installing Line Level Converter being told different things. + RCA Quest  (Read 6932 times)
Ryanedition30
Hello everyone, Im installing my stealth sub tonight and ill be posting pics step by step as i do.
Ive got a line level converter as the RNS510 does not have any pre outs.
I heard its best to take a feed from the Front Speakers as the rears have some sound filtered, however the seller says take it from the rear speaker at the rear speaker.
I was going to take the feed from the headunit.
Just wanted everyones Opinion before i do.
Also Can I just join the Converter onto the wire as I don't want to loose a speaker.
And finally, Where has everyone else taken their RCA feed from?
Thanks in advance.
Ryan
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Ive spoken to a few people who have subs put in with an rns unit, and they've taken feed from the rear speakers.
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Yeah the RCA is taken from the rear speaker, not the head unit end but at the speaker.
Let me see if i can find the correct adapters
Offline mtj2k
  • 1.4 TSi GT
I spliced one of the front speakers from the back of RNS so that i could run the RCA down past the gearstick and to the amp under the passenger seat. Worked a treat for me. Also ran a remote switch from the ciggy sockets using one of the spare buttons by the ESP and a cheap switch from maplin so that i can turn off the Sub when listening to footie  :happy2:
Offline mtj2k
  • 1.4 TSi GT
Well if you take a line off the ciggy then this only activates when the ignition is on anyway... that's what i did but with the series wired switch to enable it to be turned off too.
Only reason i went with the fronts was instinct not sure what the difference would be
Offline mtj2k
  • 1.4 TSi GT
not so sure about that one! test it with a phone charger or similar  :laugh:
  • -Receive: 453
Quick question.. does the cigerette lighter in the boot only become active when the car is on too?
Mine is powered only with the ignition on...
Offline stu_no_1
My gti was on constant for the cigarette lighters it was an 05 plate my 06 plate r32 only comes on with the ignition dunno if its an age thing maybe earlier cars stayed on
Offline JoeDarKa
  • -Given: 57
  • -Receive: 74
Sorry do dig up an old-ish thread. Do you splice into one side (left or right) of speakers or both sides (left and right)?
Iv got a line out converter running off both rear speakers but im getting some vocals coming out of the sub
Offline Llew
  • -Given: 45
Both sides
Golf 2006 tdi 140pd, dsg paddles,blue interior led lights,r32 rear bumper, cruise control,vcds,highline , r32 mfsw steering wheel, gti front bumper,miltek decat.
Offline mtj2k
  • 1.4 TSi GT
I spliced mine into just one - front left i think. The vocals on the sub should be filtered out with the amp.
Offline JoeDarKa
  • -Given: 57
  • -Receive: 74
I had the lpf too high. Still needs to be set up properly
Offline Llew
  • -Given: 45
I have a double sub but I guess if u r only using a single sub one side will be sufficient
Offline nadlad
  • GT Sport 08 140PS
If your amp supports high level input then forget your converters etc just run the speaker writes straight to your amp, see my ancient audio install by squeekuk
