September 28, 2026, 04:38:18 am
All Things Mk5
Mk5 General Area
Do I need longer wheel bolts?
Topic: Do I need longer wheel bolts? (Read 1211 times)
xjscx
Taking part
-Given: 3
-Receive: 0
May 06, 2013, 10:30:08 am »
Picked up my new wheels from luckygti and I'm not sure if the stock bolts are long enough.
They are ball seat like the oem wheels so the bolts fit fine but I only have around 10mm of thread to go into the hub. Is this safe or should I get some longer bolts?
PaulR32
Always Involved
-Given: 0
-Receive: 2
Re: Do I need longer wheel bolts?
Reply #1 on:
May 06, 2013, 10:51:20 am »
Longer defo! Put the standard bolt through the standard wheel then see how much you have sticking out. Then order new bolts to whatever length you need to have the same amount sticking out on the new wheels. You can't risk it not being long enough.
bacillus
Just look at my post count
-Given: 4
-Receive: 453
Reply #2 on:
May 06, 2013, 12:13:15 pm »
Quote from: PaulR32 on May 06, 2013, 10:51:20 am
Say no more...
xjscx
Taking part
-Given: 3
-Receive: 0
Reply #3 on:
May 06, 2013, 03:14:42 pm »
sorted. just ordered some 35mm bolts
All Things Mk5
Mk5 General Area
