Author Topic: GOLF GT SUSPENSION QUESTION  (Read 1997 times)
Offline mrxbox360
  • My Ride: 2008 Golf Mk5 GT TDI Sport 5dr Reflex Silver Personal Enchanced
« on: May 29, 2013, 12:58:26 pm »
Will ed30 standard springs fit a gt tdi 140 & will they be any different in hight on standard gt shocks
Offline gjseb16
Re: GOLF GT SUSPENSION QUESTION
« Reply #1 on: May 29, 2013, 01:39:20 pm »
i am postive they will be lower and i would of thought they should fit they are both front wheel drive cars
Offline torque777
Re: Re: GOLF GT SUSPENSION QUESTION
« Reply #2 on: May 29, 2013, 02:06:26 pm »
You should have 55mm struts if yours is a 2.0tdi 140/170 bhp ...so they should go on ...it should also be marginally lower ..a gt is 15mm lower and I think a gti is 20mm lower but can't remember if the gti is any lower than a gti
sent using my own fingers
Offline mrxbox360
« Reply #3 on: May 29, 2013, 02:10:37 pm »
cheers lads i was just concerned as in if i would any issues with bottoming out problems
Offline JoeDarKa
  • -Given: 57
  • -Receive: 74
« Reply #4 on: May 29, 2013, 05:31:29 pm »
Diesel engine weight may overload the springs?
Offline torque777
« Reply #5 on: May 29, 2013, 06:01:49 pm »
There is virtually no difference on the front with either gti or tdi ..its only the rear that change and that's only if you have a jetta or wagon as there's are slightly uprated for heavier rear
« Reply #6 on: May 29, 2013, 06:39:11 pm »
would of thought the tdi springs were different due to the extra weight the engine
