Author Topic: Control arm torque settings  (Read 1079 times)
Offline Domefc
« on: May 29, 2013, 07:29:00 pm »
Ok lads here goes [Again] just had drop links/ cv arms and joints replaced right arm had a bend in so couldnt get the camber spot on so i replaced them both now im getting a clunking noise from left hand side on full lock as i reverse out my drive way sounds like the top mounts as i had same issue with my a3 thing is before i shell out more dosh wanted to torque up all the sub frame bolts and control arms to see if that helps. Any torque settings or tips welcome cheers. :driver:
