Author Topic: Please help me with fitting a Bosch or Walbro into lpfp housing...  (Read 2569 times)
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
OK, I have the original lpfp out now and the usp lpfp is in the tank. I'm going to order another pump to rebuild the oem lpfp for the next spare. But, I need to find someone that has torn apart their pump from the housing and fitted a new inline into the housing with success and pointers so that I avoid catastrophic failure and the like ;p I've been told a Walbro would fit right in as well as a Bosch but I guess since I haven't taken mine apart yet I can't see how an inline works in that configuration. Most times I take something apart I have no issues with getting it back together correctly, but I don't want to order one unless totally convinced.
So, any help with this is gratefully appreciated ;p
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
Re: Please help me with fitting a Bosch or Walbro into lpfp housing...
« Reply #1 on: June 18, 2013, 07:53:43 pm »
I have the old one out...which was quite easy to do.
I'm trying to make up for the lack of ability to match specified. My upgraded lpfp is still lacking I guess. I know above 4bar is good, but just don't understand this discrepancy on the graph...
« Reply #2 on: June 18, 2013, 07:58:07 pm »
I suppose there is always going to be a difference between requested and actual....
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
« Reply #3 on: June 18, 2013, 08:11:36 pm »
Yes...maybe. It is managing to maintain a +4bar mark. This new lpfp is supposed to be sufficient up to 500bhp...but I believe it is a modified audi ttr pump.
http://www.uspmotorsports.com/USP-Motorsports-Low-Pressure-Fuel-System.html
I just want to go a different path by replacing the oem pump inside its lpfp housing to have as a back-up...
« Last Edit: June 18, 2013, 08:13:23 pm by ROH ECHT »
Offline vRSAlex
  • -Receive: 253
« Reply #4 on: June 18, 2013, 08:31:41 pm »
Fitting the 044 or the 255 is a pita. They are not pumps that can be voltage regulated easily. This can lead to the fuel pump controller throwing a fault.
Follow AKS tuning on Facebook
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
« Reply #5 on: June 19, 2013, 11:10:51 am »
Would you know of a VAG pump, other than a tt rs or rs3 that would be a proper upgrade similar to the modified TT RS lpfp that I just installed? And, that would also be acquirable here in the states?
