Author Topic: Bilstein B16's or KW clubsport? Discuss.  (Read 14535 times)
Re: Bilstein B16's or KW clubsport? Discuss.
« Reply #30 on: March 13, 2011, 03:53:50 pm »
I will be meeting up at the Herts meet on the 24th, I have B16's and will hopefully have some settings that I think work. It will be interesting to see how they compare to KW V3's Robin maybe you should drive my car ?
....Could be interesting. Mine have been very well set up by VWR and needed no adjustment when recently laser checked on an independent Hunter rig. The roads around J&H probably aren't ideal in the dark.
Quite honestly I would expect the Bilsteins to be excellent. It's a bit like comparing top of the range cameras from Nikon and Canon.
Offline Janner_Sy
  • -Receive: 113
« Reply #31 on: March 13, 2011, 03:59:18 pm »
I agree with RR, i bet theres very little difference between them in 'actual' perofrmance.  Everyone has their preference at the end of the day.
I think the Billies win on ease of adjustability, but the KW V3 has more adjustability
Offline Msportman
« Reply #32 on: June 19, 2013, 12:53:17 am »
I've been looking at both of these kits. I've had Clubsports before.....very comfy and good all round but once on the car I rarely adjusted them.....running 2.5 degrees neg on the front.
Are the Bilsteins as comfy / plush on the road when slackened off or are they stiffer being a mono shock. I understand Bilstein rig test and I assume the oil filled KW;s can warm up on track and soften up?
Will I get as much grip with a anti lift and anti bump kit using the Bilsteins which don't have camber adjustment or am I better re ordering KW's?
« Last Edit: June 19, 2013, 12:55:47 am by Msportman »
Pearl Black Edition 30 3 Door. DSG. (3rd Edition 30)
Maybe on the too do list: APR Stage 2+, KW Clubsports, Brakes, Diff.
