Author Topic: DSG box slipping into neutral  (Read 10973 times)
Offline Kalpsn2000
  • -Receive: 56
Re: DSG box slipping into neutral
« Reply #15 on: July 25, 2013, 10:24:22 am »
Can someone explain to me the way they use the DSG gearbox when coming to a stop at traffic lights for instance.
Do you slip it into neutral then back into D or leave it in D with the foot brake on?
For me it depends on the expected length of the stop. Usually flick it into N unless it looks like it will be a quick stop.
Offline Tamiyoman
  • -Receive: 39
« Reply #16 on: July 26, 2013, 10:57:52 am »
That's what I used to do, if it was less traffic lights just changed straight into neutral, if it was shorter stop leave it in D.
Offline wingnutLP
« Reply #17 on: February 08, 2014, 09:44:42 am »
Bugger this problem has come back. Someone suggested a dog reset via vcds can someone elaborate as to what this means?
Is it a diagnostics plug in and reset and if so is it back to vw or would independents be able to do it?
By the way I have never out the box in neutral when driving, I didn't even know you were supposed to!
Offline SRC
  • -Receive: 27
« Reply #18 on: February 08, 2014, 12:37:24 pm »
If you keep your foot on the brake when in gear, you'll feel it reduce the torque through the transmission.  Leave it in gear with only the handbrake on, and you'll feel it pulling.
Shadow blue DSG 5 door with leather, sunroof, 18" Monzas, MFSW.
Full list of mods:  Seat inserts and a VW bottle opener.  Each worth 20bhp.
Offline v4rley
  • -Receive: 104
« Reply #19 on: February 08, 2014, 12:54:16 pm »
There DSG reset guide is Here
You will need VCDS  :happy2:
Offline wingnutLP
« Reply #20 on: February 08, 2014, 01:46:30 pm »
Diagnostic said temp sensor on gearbox as previously suggested. It was just me driving through puddles too fast.
Re neutral, if your foot is flat on the brake and you are not moving it feels to me like the clutches completely disengage so I can't see a big need to put it in neutral.
I am not going to bother that is for sure :-)
Offline xjay1337
  • -Receive: 377
« Reply #21 on: February 08, 2014, 08:05:49 pm »
I don't think the DSG is designed to be held in D with the brakes on for a long time.
It emulates creeping that you get with a normal manual gearbox by inducing slip on the clutchpacks. They are wet clutches so it's not as bad as slipping a normal clutch in a dry clutch car however nevertheless is not ideal for long periods of time..
  • -Receive: 453
« Reply #22 on: February 08, 2014, 11:27:56 pm »
Additionally the dsg oil temp starts to rise when you stop in D with your foot on the brake after a short time.
Offline wingnutLP
« Reply #23 on: February 09, 2014, 01:53:19 pm »
Surely after a period stationary when the gearboxes senses the wheels are not moving and the brake is fully pressed it just fully disengages the clutches? Then when the foot comes up it comes up to biting point and starts pulling.
Clearly all the sensors are all there so why would it keep slipping the clutch rather than disengaging?
On the original topic it is still dropping into neutral even just on a wet motorway run so I think the weather sealing on the sensor must have gone.
Is the temp sensor on the top or bottom of the box? I couldn't see it on the bottom anywhere.
Offline wingnutLP
« Reply #24 on: March 03, 2014, 09:11:29 am »
I had the temperature sensor changed which was an oil out costing £300 at an independent and the problem seems to have gone away.
Thanks for the advice.
