Author Topic: Headlamp Adjustment/Deflectors for driving in Europe  (Read 4262 times)
Offline f1fan
« on: July 09, 2013, 02:45:09 pm »
I'm taking my GTi over to France in a couple of weeks time so thought about getting all the usual guff like triangles, hi-viz jackets etc all sorted out.  As it's the first time I've taken the GTi abroad I've not had to deal with adjusting the headlamps so I don't dazzle other cars.
Do the GTi lights need to be adjusted?  Are they Asymmetric or Symmetric lights?  i.e.  _ _/  or _ _
How have you guys dealt with this?
Black 2008 GTi, InPro smoked door mirror indicators, genuine Autohaus Wolfsburg plate holders, uk legal pressed metal plates, LED number plate lights, MTEC super white headlights & side lights, LED internal lights, Polo stubby aerial, Kenwood DDX4023BT head unit & Enfig surround.
Offline OSB
  • -Given: 32
Re: Headlamp Adjustment/Deflectors for driving in Europe
« Reply #1 on: July 09, 2013, 05:01:21 pm »
I started a similar thread a short while ago. Can't find the link at the mo but if I do I'll post it.
I decided to get some stick on beam deflectors - ebay, only a few quid. These are ones which are supposed NOT to reflect too much heat.
As it's unlikely I will do much if any nightime driving, I'm only going to stick them on if needed. The problem being that they can be a b****er to get off cleanly! It's difficult to scrape the plastic cover without damage.
I have heard that Isopropyl alchohol will dissolve the sticky without damage to the plastic. I'm going to try a hidden area tonight to see the effect. I'll post results.
Hope that helps a bit!
Offline OSB
  • -Given: 32
Offline OSB
  • -Given: 32
« Reply #3 on: July 09, 2013, 05:20:00 pm »
Just tested Isopropyl alcohol on a hidden area of the head lamp front and no effect. It also cleared some well stuck on beam deflector remains from my neighbours car. Result!
  • -Receive: 453
« Reply #4 on: July 09, 2013, 05:24:28 pm »
Have a look here if you have xenon headlights.  :smiley:
http://www.thewindinglane.co.uk/images/pdf/xenon.pdf
Offline f1fan
« Reply #5 on: July 09, 2013, 10:23:19 pm »
Thanks for the link, I did a search for 'abroad' and didnt find it before I posted.
I have standard Halogens so will go for the stickers.
Where did you buy the Isopropyl from?
Offline OSB
  • -Given: 32
« Reply #6 on: July 10, 2013, 07:56:30 am »
I scrounged a small bottle of Isopropyl from work!
But you can get it on ebay quite cheap. It's useful stuff for fine cleaning and degreasing small parts.
