Author Topic: Where can I buy a PCV valve?  (Read 1884 times)
Offline Craigh1983
    • Leicester Wedding Photographers
« on: July 16, 2013, 07:56:28 am »
Hi guys,
Thought my PCV had failed at the weekend so I took the main pipe off to do a blow test and ended up snapping it in half lol
So I was just wondering is it best to go straight to VW for the parts or is there a website that someone can recommend where I can buy the parts I need?
Been having a look around on the net but cant seem to find anywhere that do them.
Craigh
Offline skard
  • -Receive: 245
Re: Where can I buy a PCV valve?
« Reply #1 on: July 16, 2013, 08:22:27 am »
Yes, cheap enough from a VAG dealer, doesn't have to be VW as it is used across the range.
I got mine from David @ SERE motors who does mail order too.
Also try a local TPS branch.
Offline edd666999
  • -Receive: 89
« Reply #2 on: July 16, 2013, 08:25:35 am »
If tps is close go there.
If not VW will be £3/4 more expensive but could be closer.
Offline Craigh1983
« Reply #3 on: July 16, 2013, 09:55:52 am »
I've just looked and u do have a tps near me :)
Will give them a call.
Cheers :)
Offline john a
    • The Veneers Cover Band
« Reply #4 on: July 16, 2013, 07:16:16 pm »
Do you know what revision you need? I have a rev P (or possibly N) I've never used.
Offline edd666999
  • -Receive: 89
« Reply #5 on: July 16, 2013, 09:32:50 pm »
its the pipe he needs not the actual PCV i think.
Offline Craigh1983
« Reply #6 on: July 17, 2013, 07:40:28 am »
Yea its just the pipe thanks. PCV turned out to be fine.
Called TPS though and they want £15 for a bit of plastic pipe lol
Offline edd666999
  • -Receive: 89
« Reply #7 on: July 17, 2013, 07:43:52 am »
just replaced mine and yep £15.
dont forget its got fancy clips on the end of it.  :grin:
