Author Topic: remapped at rtech stage 1  (Read 4826 times)
Offline alexharvey
« on: July 30, 2013, 11:44:56 pm »
hi guys bit of advice had the car remapped on pipercross panel filter i now intend on getting the pre cat out and fitting ITG induction kit , do i need to get map tweaked after doing this? or will it adjust to more airflow?
also i must say top service and map by the r tech guys!
thanks Alex
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
Re: remapped at rtech stage 1
« Reply #1 on: July 31, 2013, 09:59:32 pm »
You could have e map tweaked but you won't get much more than the ECU will adjust for anyway
Offline alexharvey
« Reply #2 on: August 01, 2013, 12:15:34 am »
thanks gray will get tweaked when get intercooler etc then!
Offline patpong_pete
« Reply #3 on: August 01, 2013, 04:20:39 pm »
to get good bhp from re map what do u need ?
new DV G type check done that
panel filter ? is it any better than original
decat take out white chalky stuff or just change downpipe what would that make bhp ?
cat back exhaust bhp ?or both
what would the figures be 240 bhp
thanks for reply pete
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #4 on: August 01, 2013, 06:37:49 pm »
Do this:
-panel filter
- remove pre cat from down pipe
- stage 1 map. Should easy make 240bhp (even on JKM's dyno  :grin:)
Offline alexharvey
« Reply #5 on: August 02, 2013, 12:29:48 am »
i had just a panel filter and always run my cars on Vpower fuel at my remap and made 245 bhp and 307 ft pounds torque. thats was at r tech
car is great now just want a bit more!! hence taking out pre cat and induction kit
think this is getting addictive!!!
 :rolleye:
Offline alexharvey
« Reply #6 on: August 04, 2013, 10:32:02 pm »
how long does it take to adjust u think?
Offline james
« Reply #7 on: August 06, 2013, 06:46:00 am »
just d/c the battery,  let it learn from scratch. :drinking:
« Reply #8 on: August 06, 2013, 09:59:52 pm »
 :rolleye:
taking out pre cat  will you do this yourself or get nick at r tec to do this ?
do u know what he charges and what bhp extra it could make ?
Offline alexharvey
« Reply #9 on: August 07, 2013, 01:50:56 am »
im gonna take the pre cat out myself , been told up too 5 bhp plus better air flow and cooler temps in exhaust will work well with induction and map!
think i may try to let it learn from scratch do i need to leave battery off a while and is it best to drive it fairly quickly after?
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #10 on: August 07, 2013, 08:18:08 pm »
Mine adapted very quickly afterwards  :happy2:
There was a noticeable difference straight away.
Offline R-tech-Nick
  • -Receive: 30
    • R-Tech Performance Tuning
« Reply #11 on: August 11, 2013, 10:02:30 am »
Everything to aid flow now will compliment the mapping, don't worry about having to have the map changed again until u have done all the hardware for the next sw stage of tune, then you can have the mapping adjusted to take full advantage of your hardware investment.  :-)
01455 617233
Offline alexharvey
« Reply #12 on: August 11, 2013, 09:55:00 pm »
thanks nick will do!  ill get hpfp and intercooler s3 one that should be ok do i need new exhaust?
and anyone got any ideas on which hpfp? apr?
alex
« Reply #13 on: August 11, 2013, 11:11:08 pm »
APR HPFP FTW.  :happy2:
Their rebuild pumps are £480 ish, send them a new OEM pump (£150 ish) and they'll send you back a shiny new APR HPFP. Or a LOBA HPFP for £599.
Offline alexharvey
« Reply #14 on: August 12, 2013, 01:26:51 am »
thanks mc 71
