Author Topic: Passat b6 rcd 300 to rcd 310  (Read 2339 times)
Offline Neiltdi
  • Full Hex+CAN
« on: August 14, 2013, 08:39:18 pm »
Hi
I have a friend looking to upgrade there rcd 300 to a 310
The last letter of the part number for the gateway is c , does this need a gateway upgrade? Or will it not suffer with battery drain?
As this is the 3rd gen of the units im now thinking it will need the upgrade?
Would a 500 be okay without a new gateway?
Neil
Full Hex+CAN in Hampshire.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: Passat b6 rcd 300 to rcd 310
« Reply #1 on: August 14, 2013, 08:48:22 pm »
he will require a passat gateway 3c0 907 530Q
if upgrading to a 3rd gen radio
Cluster and Key coding
Location Great Yarmouth
Offline Neiltdi
  • Full Hex+CAN
« Reply #2 on: August 14, 2013, 09:04:19 pm »
Hi eddie thanks for the reply i guess there is no way around the issue without a gateway upgrade?
Do you know how much this gateway is? Ebay doesnt come up with anything if i search the P/N.
I guess a golf gateway wont be compatible?
