Author Topic: oil cooler replaced car came back no map?  (Read 1282 times)
Offline alexharvey
« on: August 20, 2013, 07:13:13 pm »
Hi guys wonder if any one has any ideas what happened
Took my car to garage to have oil cooler replaced and when I collected car was driving like no remap or worse than standard car !!
The car has a r tech remap , itg intake and precat delete and was running perfect before went to garage today!!
Spoken to garage and they said they would have a look tom just wondered if anyone had any ideas because changing oil cooler should be easy job and not affect r tech remap or anything
Thanks in advance alex
Offline doylebros
  • -Receive: 310
Re: oil cooler replaced car came back no map?
« Reply #1 on: August 20, 2013, 07:17:41 pm »
Boost Pipe off or not clipped in?
Offline Sie
« Reply #2 on: August 20, 2013, 07:27:11 pm »
Had battery disconnected?
Simon
Fettled Laser Blue '05 GTi 5dr
  • -Receive: 453
« Reply #3 on: August 20, 2013, 07:32:04 pm »
If it was a VW garage then it's possible they updated your ecu software without informing you and wiped your map.
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 249
« Reply #4 on: August 20, 2013, 07:34:21 pm »
Simon
That won't affect an R-Tech map.
It sounds like VW have updated the ECU  :sad1:
Offline alexharvey
« Reply #5 on: August 20, 2013, 07:59:38 pm »
Thanks for responded guys v quick sorry should have said wasn't vw garage was local garage to me and normally do good job on mums car etc , can't see any pipes off from under bonnet
Offline alexharvey
« Reply #6 on: August 20, 2013, 09:31:40 pm »
Just tested car again , and still not right , and no dv noise dumping air or what ever it does I'm hoping its a pipe off as seems no boost at all ?
Offline alexharvey
« Reply #7 on: August 22, 2013, 01:05:37 pm »
By way of update , car sorted , mechanic said was computer error and code cleared , think he talking rubbish in front of his boss , I think was a pipe left of as no boost his boss agreed
Anyway all good now , thanks for replies
