Author Topic: 235/35/r19 wheels will they fit my car  (Read 15288 times)
Offline axsweb
« on: September 01, 2013, 06:52:02 pm »
Will these wheels 235/35/19 fit my golf? It's a mk5 golf gt tdi 07 reg. also what's the brand of the alloys?
  • -Receive: 453
Re: 235/35/r19 wheels will they fit my car
« Reply #1 on: September 01, 2013, 09:57:13 pm »
You'll need to find out the pcd and offset of those rims.
« Reply #2 on: September 01, 2013, 11:23:31 pm »
235/35/19 are the tyre sizes mate.
You need to find out the specs of the wheels...
PCD = You need 5x112 on the mk5 Golf
Offset = This should be around ET42 to ET45 in my opinion
Wheel width = 7.5",  8",  8.5" I think they will prob be 8.5" if the tyres are 235.
Offline AndrewJB
  • die gelbe Baron
« Reply #3 on: September 02, 2013, 04:21:10 am »
my car (MK2 Leon Cupra R) came out of the factory with wheels fitted with 235/35/R19 tyres on them, SEAT added little plastic "wings" on the rear arches to make them slightly wider for the MOT rules
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
Re:
« Reply #4 on: September 02, 2013, 07:09:33 am »
My mk5 has 19" wheels
8.5J et43 with 235/35 tyres
They fit fine, although I haven't tried with passengers yet.
Jas
VCDS (Preston, Lancashire)
Offline axsweb
« Reply #5 on: September 02, 2013, 01:01:32 pm »
Ok, I'll find the sizes and see what it is.
Offline axsweb
« Reply #6 on: September 02, 2013, 06:02:58 pm »
right on the inside of the rim i found some number
they say 19x8jj and et35
i think there the ones
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
Re:
« Reply #7 on: September 02, 2013, 06:14:40 pm »
Jas
Think yours are 225 Jas   :innocent:
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #8 on: September 02, 2013, 06:16:47 pm »
Yep them's the one's  :happy2:
ET 35 will probably cause some rubbing if you lowered
Maybe a 225 tyre might be better on those?
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
Re: Re: Re:
« Reply #9 on: September 02, 2013, 06:30:14 pm »
Jas
You're right! Dunno why I thought they were 235. Lol.
Offline axsweb
« Reply #10 on: September 02, 2013, 06:57:00 pm »
not thinking about lowering at the moment, but is on to do list. This means the wheels will fit on? how do i find what brand they are?
 :confused:
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #11 on: September 02, 2013, 08:07:53 pm »
Ok if your not lowered then you'll be ok, you'll just have a bit of poke.
Regards brand, is there nothing else on the inside of the rim?
Offline axsweb
« Reply #12 on: September 03, 2013, 03:20:03 pm »
There's some random numbers on the inside of the rim.
I'll post a picture if it helps
Also when you said 'I'll just have a bit of poke' do you mean they'll stick out a bit or will they rub against the arches?
Offline xjay1337
  • -Receive: 377
Re: Re: Re:
« Reply #13 on: September 03, 2013, 03:41:55 pm »
Jas
[/quote]
[/quote]
I rub with 215/35 on ET44 (sits 1mm further in away from the arch) so have fun with that lol
Unfortunately most people on this forum don't understand stretch or fitment or stance  :confused: :confused:
19x8 et 35 will fit but I would recommend 215/35 tyres. Unfortunately it's either that or 235/35 or 40s which give a weird look and can (and probably will) cause clearance issues.
Putting wheels on a car without lowering it almost always makes it look a bit silly  :laugh:
You can fit quite a wide range of ETs on a Mk5..
Depends on width but you can fit a 9.5j et 30 on the rear quite happily. The fronts the most you can realistically fit is a 19x9 et41 (bentley).
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
Re:
« Reply #14 on: September 03, 2013, 07:15:41 pm »
I admit I don't have a clue about wheel fitments.
Mine don't rub though.
Haven't lowered yet though so that may change :confused:
