Author Topic: Wheels & Offset, have I ****** Up?  (Read 13781 times)
Offline jaffa
  • -Receive: 44
Re: Wheels & Offset, have I ****** Up?
« Reply #45 on: September 10, 2013, 12:01:16 am »
the lower the better
« Reply #46 on: September 10, 2013, 07:48:25 am »
Does anyone actually know the perfect offsets/widths for the mk5 without causing any arch problems and not needing to start playing with camber?
For me I always go for....
8" wide wheels with ET 44/45
Perfect. Even when lowered  :happy2:
Offline Tim144
« Reply #47 on: September 10, 2013, 12:33:27 pm »
8.5/9 all at et20 flush!
Offline xjay1337
  • -Receive: 377
« Reply #48 on: September 10, 2013, 12:59:50 pm »
There's a big difference between 8.5 and 9s at ET20..
Neither of which will fit on the front without a lot of work. Rears would need max camber and huge stretch.
Offline raymondo1234
« Reply #49 on: September 10, 2013, 01:01:54 pm »
going lower that et38 on 8j will need 215/35/40 IMO
as I said before, on et35 on 225/40/18 8j even with arch mod, caused me no end of trouble when on fk coilovers. Looks great and no probs since changing the tyres, my coilovers r as low as I can go, and the ride is nowhere near as bad as I thought it would be.
Offline xjay1337
  • -Receive: 377
« Reply #50 on: September 10, 2013, 08:16:26 pm »
I have Et44 18x8.5 and even with 215/35 it rubs on the front arches if I go low enough.. having put new arches on I run the car higher. You need to get them rolled once you approach this sort of level to be honest.
8j et 35 on 225/40 would never work when lowered  :grin: this is where people need to check tyre sizes and clearances first!
Offline jonnym
  • -Given: 40
« Reply #51 on: September 10, 2013, 09:41:00 pm »
I ran (and soon will have another set) RS dish rims -
Front: 8.5J 18" ET40 (no spacers) 215/35 with stretch
Rear: 9.5J 18" ET35 (5mm spacers) 225/40 with stretch
Backs ran fine and spacers saved the shocks being hit. I also had about 2/2.5% camber to help aswell. Fronts didn't really rub although depended on low you go and I was proper low then.....until I slammed into a few corners and my arches buckled slightly.
Atm, i've got 8J all round with ET42. I'm low, but not too much, and need to roll my arches just a tad to ensure my hard cornering doesn't rub further. They don't sit 100% flush but clearly I can't do what I want to do if they are flush.
