October 08, 2026, 10:57:41 am
All Things Mk5
Mk5 General Area
New, Redo, Intake Valve Cleaning DIY Video
Topic: New, Redo, Intake Valve Cleaning DIY Video (Read 1154 times)
ROH ECHT
Just look at my post count
-Given: 113
-Receive: 149
K04 PLAY....ZOOM DIS!
September 25, 2013, 02:37:06 am »
I did a redo of the cleaning with a new sprayer that will be easier for more to use and do valve cleanings for themselves ;p
Much simpler to do as there are no mod's necessary for the sprayer other than trimming down the ribs that were on the new nozzle so it would fit perfectly inside the IAT port ;p
Please enjoy and do often(every 10k miles or so):
http://www.youtube.com/watch?v=hHF-Jdw0eto
K04 PLAY...K04 turbo/S3 INJ. & FMIC/FORGE FMTC, TB hose, & WG actuator/GIAC's H.O. K04 & DSG TUNES/AWE DV/NEUSPEED P-FLO,TURBO OUTLET & TB pipe/AUTOTECH hpfp/BSH Eng.&Trans Mounts/H&R ARB's/Whiteline Performance springs & W.A.L.K./ECS stage-3 BBK/BILSTEIN B8's...ZOOM'DIS...GIAC K04 tune-2007 Volkswagen GTI: 12.823 @ 112.050 MPH__Voting for my Dragtimes link:
http://www.dragtimes.com/Volkswagen-GTI-Timeslip-25700.html?r=1
ROH ECHT
-Given: 113
-Receive: 149
Re: New, Redo, Intake Valve Cleaning DIY Video
Reply #1 on:
September 25, 2013, 07:06:33 am »
I believe my past valve diy vid was moved...so OK to replace it with this one ;p Where ever it is...
ROH ECHT
-Given: 113
-Receive: 149
Reply #2 on:
September 25, 2013, 10:25:07 am »
Bore-scope pics provided by martziniuk @
http://www.mk5golfgti.co.uk/forum/index.php/topic,72375.msg771396.html#msg771396
Before:
After:
ROH ECHT
-Given: 113
-Receive: 149
Reply #3 on:
September 25, 2013, 10:22:38 pm »
I used the RL Flomaster deck sprayer...I found in the paint dept. at Ho-depot for under $11...! The ribs on the "fixed fan-nozzle" need to be removed...so I just used a sharp blade to slide underneath each one. It is very soft material and easy to remove...then it will fit perfectly inside the IAT sensor ;p
http://www.homedepot.com/p/RL-Flo-Master-1-5-Gal-Deck-Sprayer-1415D/100637818#.UkNQ_hDpzug
All Things Mk5
Mk5 General Area
