Author Topic: heated leather need help  (Read 1220 times)
Offline golfgti10
« on: October 02, 2013, 04:19:16 pm »
looking to buy some leather seats but they are heated and my seats aren't, can I just plug and play the new leather seats and have no problems with dash lights such as airbag???
Offline skard
  • -Receive: 245
Re: heated leather need help
« Reply #1 on: October 02, 2013, 04:39:08 pm »
Yes seats will fit in, I think some years have a difference in the plug for airbags but this can be modded.
It would also be a complete shame not to wire up the heated seats so you can purchase a loom from Kufatec and new heater panel and get them working eventually.
Offline danfalcon
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,92069.0.html
« Reply #2 on: October 02, 2013, 06:18:38 pm »
As Skard said, you will need the loom - http://www.kufatec.co.uk/shop/en/volkswagen/golf/golf-5-golf-5-plus-1k/seat-heating-harness-vw-golf-5
the control panel which varies depending on whether you car has standard heating/AC/climatronic
and here is an amazing guide written by a member of the forum http://www.mk5golfgti.co.uk/forum/index.php/topic,62645.0.html
Offline golfgti10
« Reply #3 on: October 02, 2013, 06:35:48 pm »
so they will fit fine no problems no dash lights I will just have a loose wire right for the heated bit
Offline skard
  • -Receive: 245
« Reply #4 on: October 02, 2013, 07:34:50 pm »
You will have to disconnect the battery before commencing, upon reconnecting you'll have the ESP fault where you need to turn full lock each way when stationery, then drive forward slowly for it to go out.
Otherwise you'll log an airbag fault by disconnecting seats with the battery connected.
And as I mentioned, this is assuming your new seats airbag plug match the old ones.
Offline golfgti10
« Reply #5 on: October 02, 2013, 08:52:52 pm »
my car is 2004 these seats are 2008
Offline skard
  • -Receive: 245
« Reply #6 on: October 02, 2013, 08:56:35 pm »
I don't know, when I previously did it my plugs matched up. Best thing to do would be get pics off the seller and compare them to yours.
