Author Topic: Tyre Valves  (Read 1357 times)
Offline Carla77
Tyre Valves
« on: November 07, 2013, 09:49:12 pm »
Hi,
Front offside tyre seems to be losing pressure quite quickly and I've been having to pump up the tyre every few days.
Took my car to a local garage and asked him to check if there was a problem with the valve and to replace - he then said that the ones for our car cost arond £70 as they incoporate the sensors that link to the tyre pressure warning light on the dash. I was also told that most people with our cars change these for a 'normal' valve if they have any problems.
Anyone had any problems with the valve; is it true that they're £70 to replace and do people tend to swap them out with the 'standard' valves.
  • -Receive: 453
Re: Tyre Valves
« Reply #1 on: November 07, 2013, 10:02:41 pm »
Total BS!
The UK and EU cars don't come with a TPMS associated with the valve but the North American ones do. Our system relies on the abs sensors to detect changing rolling circumference.
Depending on your rim you may need a special VW metal valve but otherwise a standard valve should work.
Offline Homer
Re: Tyre Valves
« Reply #2 on: November 07, 2013, 10:19:10 pm »
Either they guy is lying or doesn't have a clue. Go elsewhere.
Offline Marc-5-GTI
Re: Tyre Valves
« Reply #3 on: November 07, 2013, 10:30:51 pm »
Total BS!
This..
Should only really be the cost of fitting a tyre, as the cost of a valve is included in that..
Offline Frodo-anni
  • -Receive: 45
Re: Tyre Valves
« Reply #4 on: November 08, 2013, 10:19:40 am »
Monza's? They do have two different types of valve that can be used. The early BBS version 'hollowtech' can only use a certain type of metal valve that are approx £17 each. But as above the TPMS i do not believe.   :signLOL:
mk5 GTI Edition 30 DSG No0391
Offline Carla77
Re: Tyre Valves
« Reply #5 on: November 09, 2013, 09:19:23 pm »
Cheers guys....I have a 54 reg so it's probably the metal valve that the guy is talking about. However, big difference between £17 and £70 and the tall tale about the TPMS!
Thanks again.
Offline Frodo-anni
  • -Receive: 45
Re: Tyre Valves
« Reply #6 on: November 10, 2013, 08:37:58 pm »
Thanks again.
My monza's are from an early car, 54/05 i think and require the metal type valves. I believe they can be reused. Fingers crossed i'll find out next week when i try fit my winter wheels.  :signLOL:
