Author Topic: Abs light, traction control light, tyre pressure light  (Read 24915 times)
Offline Andy1994
« on: November 26, 2013, 05:37:55 pm »
1 fault found: ABS wheel speed sensor rear right (g44)
                      003 - mechanical failure - intermitent
does this suggest the sensor is faulty or the abs ring on the bearing or something else?
Offline Andy1994
Re: Abs light, traction control light, tyre pressure light
« Reply #1 on: November 26, 2013, 07:49:50 pm »
Bump thanks for any help
Offline Matto
  • -Receive: 116
« Reply #2 on: November 26, 2013, 08:52:44 pm »
I think you're missing the main fault code number.
« Last Edit: November 26, 2013, 08:55:36 pm by Matto »
Offline doylebros
  • -Receive: 310
Offline Matto
  • -Receive: 116
« Reply #4 on: November 26, 2013, 09:00:18 pm »
Also just found this:
00287 - ABS Wheel Speed Sensor Rear Right (G44): Mechanical Malfunction
Possible Causes
Excessive Air Gap between ABS Wheel Speed Sensor Rear Right (G44) and Rotor
Short Circuit in Wiring from/to ABS Wheel Speed Sensor Rear Right (G44)
ABS Wheel Speed Sensor Rear Right (G44) faulty
Possible Solutions
Check ABS Wheel Speed Sensor Rear Right (G44) Installation
Check Wiring from/to ABS Wheel Speed Sensor Rear Right (G44)
Offline STU-HILL
« Reply #5 on: November 26, 2013, 09:02:16 pm »
I've got this exact same problem.
All there lights (ABS, Tyre, ESP) came on one day when driving.
They go off when turn off engine and start again but come back on after few miles driving.
Just been to garage today. They said was was showing error code for rear sensor so replaced it but all lights stayed on and now, the power steering has gone and that warning light stays on too. So they made it worse!!
They told me it needs to go to a VW dealer as it could be the ECU.
I had the ECU replaced 10months ago at a huge cost so It better not be that again.
Does anyone know if ECU are typically covered under warranty?
p.s I'm no car buff so I may have some info/wording wrong
Any help or theories on what it could be would be much appreciated
Offline doylebros
  • -Receive: 310
« Reply #6 on: November 26, 2013, 09:07:05 pm »
Both the sensor and wheel bearings are common problems  - you can test the sensor with a multi Meter or VCDS.
Last member who had this problem was Bower - read his posts as he had a torrid time but did sort it!
Offline bower
« Reply #7 on: November 26, 2013, 10:19:38 pm »
just had this problem myself.
i started with the cheaper/easy option and changed the speed sensor, that cleared fault for a few days but came back, i then changed the wheel bearing (abs ring built in) and fault has now gone. no way is it ecu its either one of the above
Offline Andy1994
« Reply #8 on: November 27, 2013, 06:49:53 am »
Was thinking it was more the bearing as the fault is intermittent, is there anything else I can check on vagcom to confirm it?
Offline bower
« Reply #9 on: November 27, 2013, 07:10:11 am »
yeah mine was intermittent too but as time went by the lights came on more and more often.
as far as i know there isnt?
Offline webby888
« Reply #10 on: November 27, 2013, 12:55:49 pm »
Iv had this problem twice, both times was the abs sensor in the wheel bearing
Offline Meeky
« Reply #11 on: November 27, 2013, 01:23:40 pm »
I've same problem abs rear left sensor! Easy swap in and swap out job with a few wires or is there more to it than that?
Vw Golf MK5 GTi '05 Diamond Black
Offline Andy1994
« Reply #12 on: November 27, 2013, 03:00:57 pm »
The abs ring in the wheel bearing or the abs sensor itself
Offline bower
« Reply #13 on: November 27, 2013, 06:22:31 pm »
its pretty easy one connector to remove and a allen nut but it will be wedged in there so only way to get it out is to break it out
Offline bimbound
« Reply #14 on: November 27, 2013, 07:41:06 pm »
To those who have replaced the sensor and successfully resolved the issue, did the sensor have visible sign of wear?
I have the same lights on and took the sensor out with the intention of replacing it but had been sent the wrong part, the old sensor was visibly worn at the reluctor end, I had to put the worn sensor back in and i've not since gotten around to replacing it with the correct part.
Just wondering if its normal for the sensor to show wear, or if this is a likely sign the baring/reluctor is shot?
