September 10, 2026, 05:46:28 pm
All Things Mk5
Mk5 General Area
Front top mounts
Topic: Front top mounts (Read 1759 times)
cass
Taking part
-Given: 0
-Receive: 1
Front top mounts
December 14, 2013, 05:12:44 pm »
Hi guys need so help, I'm in the middle of replacing my top mounts but not having any joy. I've removed the strut nut and the three for the top mount but the strut just doesn't want to drop down. I've read on a few places on the internet that this is all I need to do......but no joy. Can anyone point me in the right direction
Scottymon
Just look at my post count
-Given: 83
-Receive: 125
UnNaturally Aspirated
My Ride:
Re: Front top mounts
Reply #1 on:
December 14, 2013, 05:21:49 pm »
I've no experience with changing suspension, but does the spring need to be compressed?
I've got a slight knocking over bumps recently, so am interested in this as a DIY if easy, but thought spring compressors would be required...
cass
Taking part
-Given: 0
-Receive: 1
Reply #2 on:
December 14, 2013, 05:54:22 pm »
Yeah sorry forgot to mention that bit I've compressed the spring as well
doylebros
-Given: 44
-Receive: 310
Reply #3 on:
December 14, 2013, 08:03:50 pm »
Read what this link has to offer
http://vwts.ru/suspension/g5/g5_40-6.pdf
Last Edit: December 14, 2013, 08:11:48 pm by doylebros
cass
Taking part
-Given: 0
-Receive: 1
Reply #4 on:
December 14, 2013, 09:04:37 pm »
Cheers doylebros.... I've seen one like this and that's what I will do tomorrow. But I've also seen one where all you do is compress the spring and undo all the bolts on top and the arm should drop down. I've undone the bolts ,compressed the spring and it hasn't moved any even when I'm standing on the brake disk?
doylebros
-Given: 44
-Receive: 310
Reply #5 on:
December 14, 2013, 09:09:06 pm »
You need that tool 3424 or similar (chisel) have you undertaken that action so you can get the strut out?
doylebros
-Given: 44
-Receive: 310
Reply #6 on:
December 14, 2013, 09:19:14 pm »
This is worth a read including the links.
http://forums.vwvortex.com/showthread.php?4934930-How-to-remove-reinstall-front-struts-to-replace-springs&p=66392961#post66392961
cass
Taking part
-Given: 0
-Receive: 1
Reply #7 on:
December 14, 2013, 10:05:14 pm »
Cheers for the help guys. Gonna put it back together tomorrow, get the right tools and then attempt it
All Things Mk5
Mk5 General Area
Front top mounts
