Author Topic: oils  (Read 3390 times)
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
Re: oils
« Reply #15 on: January 26, 2014, 10:10:12 am »
X2 for the Millers gearbox oil
Mine runs far smoother since changing
Offline richtung
  • -Receive: 56
Re: oils
« Reply #16 on: January 26, 2014, 10:45:28 am »
VW 504 507 spec is the vital bit!
Only if you are sticking with the stock longlife 5w30.  If the car is out of warranty then you can use a better oil.
These engines suffer from burning oil when tuned and using longlife.  I switch 90% of the cars over to the millers nanodrive and they run smoother and don't burn oil.
Alex, im currently run a bog standard Ed30 and do approx 6k a year. I use Castrol Edge 5w30. I have the oil and filter changed every 6 months. Any real life benefit of me moving onto the Millers Nano drive? If i only changed out the oil once a year at service time, the cost is about the same as what i pay now.
Would be interesting to hear your views..
Rich
Re: oils
« Reply #17 on: January 26, 2014, 11:23:20 am »
Another + for the Millers 5w40 nano. Mine uses hardly a drop of oil and has reduced fuel pump follower wear to almost zero.
Offline Simmo
Re: oils
« Reply #18 on: January 26, 2014, 02:02:48 pm »
Millers nano, Castrol gtx or mobile1 IMO
Oem vw for dsg box
Not sure for manual box
Offline Jonathon555
Re: oils
« Reply #19 on: January 26, 2014, 02:40:23 pm »
Oem vw for dsg box
GTX ? Thought that was for cortinas
Offline Gman30
  • Mk1 GTI to a MK5 GTI Edition 30
Re: oils
« Reply #20 on: January 26, 2014, 05:32:13 pm »
Either use stock box oil, or millers crx 75 w 90 nt.  I use the millers on cars that crunch and it cures them.
Yup since running the Nanodrive mine feels a lil smoother and doesn't seem to be burning as much over Castrol Edge I was using before.
Offline Gra
Re: oils
« Reply #21 on: January 26, 2014, 11:45:30 pm »
I'm currently useing castrol edge 5w30 seems ok so would it be worth the swap? Il goto be for the gear box oil then yea?  What about filters I prefer to stick to genuine parts but is there any cheaper you would recommend?
Offline greygti
Re: oils
« Reply #22 on: January 27, 2014, 12:04:17 am »
Oem vw for dsg box
Lol  :grin: defo for cortinas
Offline greygti
Re: oils
« Reply #23 on: January 27, 2014, 12:06:24 am »
Yep I used motul power v300 5w 40 and my gti ran much smoother ! Didn't burn hardly any oil
Offline Simmo
Re: oils
« Reply #24 on: February 01, 2014, 04:17:25 pm »
Oem vw for dsg box
Haha not gtx sorry was replying to a turbo thread and this one at the same time and then forgot to update  :stupid:
Castrol Edge not GTX
