Author Topic: 5mm spacer  (Read 1436 times)
Offline Tommyt90
5mm spacer
« on: February 11, 2014, 10:36:30 pm »
Just a quick 1 as I keep seeing different answers. With 5mm hub centric spacers will I need longer bolts. For a gti if that helps
  • -Receive: 453
Re: 5mm spacer
« Reply #1 on: February 11, 2014, 10:38:58 pm »
Yes you should use longer bolt...
Offline xjay1337
  • -Receive: 377
Re: 5mm spacer
« Reply #2 on: February 11, 2014, 11:54:31 pm »
You may find loads of detail on the web that says no, you'll be OK, but I would always run an appropriate length bolt.
Offline dan930
  • -Receive: 56
Re: 5mm spacer
« Reply #3 on: February 12, 2014, 12:01:55 am »
Did t know u can get hubcentric spacer in 5mm!!thought minimum was 8mm
MK6 golfR dsg
AKS TUNED
NORTECH PERFORMANCE HTA3071
R TECH custom map
  • -Receive: 453
Re: 5mm spacer
« Reply #4 on: February 12, 2014, 08:17:05 am »
The 5mm one is described as hubcentric but there's no lip on it...
Offline Wooosh
  • -Receive: 87
  • Factory ponies.
Re: 5mm spacer
« Reply #5 on: February 12, 2014, 02:46:51 pm »
Didn't know u can get hubcentric spacer in 5mm!!thought minimum was 8mm
Agreed, I'm sure you can't get 5mm hubcentric spacers.
Stage 2 MK5 GTI Revo GONE
Stage 1+ MK5 GTI R-Tech GONE
Offline Tommyt90
Re: 5mm spacer
« Reply #6 on: February 12, 2014, 06:51:22 pm »
Just browsing around on eBay and they said they was hahah. Loads off people have told me different like you can no your can't websites your ok upto 7mm.  Least I no now. Cheers for the help lads
