Author Topic: Faults found help  (Read 5511 times)
Offline jakex181
Faults found help
« on: February 21, 2014, 05:55:23 pm »
Ive just scanned my car with Vagcom and as can be seen i have a few faults, im just looking for some guidance on what these mean and how to put these right. Heres the scan.
Friday,21,February,2014,17:37:10:32264
VCDS Version: Release 11.11.3
Data version: 20120401
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 55 56 76
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
76-Park Assist -- Status: OK 0000
Address 01: Engine        Labels: 06F-907-115-AXX.lbl
   Part No SW: 1K0 907 115 J    HW: 8P0 907 115 B
   Component: 2.0l R4/4V TFSI     0030
   Revision: --H14---    Serial number: VWZ7Z0F8040446
   Coding: 0403000318070060
   Shop #: WSC 00200 210 89989
   VCID: 2D5B176DB40A1F1
2 Faults Found:
012691 - Intake Manifold Runner Control
               P3193 - 002 - Open Stop outside of Valid Range - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 136681 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 53.0°C
                    Temperature: 47.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 11.811 V
001602 - Sensor Reference Voltage A: Circuit
               P0642 - 002 - Low - Intermittent
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 136681 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 53.0°C
                    Temperature: 47.0°C
                    Voltage: 11.938 V
Readiness: 0000 0000
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No SW: 1K0 907 379 AC    HW: 1K0 907 379 AC
   Component: ESP FRONT MK60      0101
   Revision: 00H11001
   Coding: 0004738
   Shop #: WSC 01279 785 00200
   VCID: 73EFC11512AE091
No fault code found.
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No SW: 1K0 907 044 BJ    HW: 1K0 907 044 BJ
   Component: ClimatronicPQ35 090 0909
   Revision: 00090016    Serial number: 00000000000000
   Shop #: WSC 00000 000 00000
   VCID: 70E5CE1963B8329
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 E    HW: 3C0 937 049 E
   Component: Bordnetz-SG     H37 1002
   Revision: 00H37000    Serial number: 00000004246535
   Coding: E78F8F2700041500001400001400000000087F075C
   Shop #: WSC 00000 785 00200
   VCID: 2B5F19758A1E111
   Subsystem 1 - Part No: 1K2 955 119 E  Labels: 1KX-955-119.CLB
   Component: Wischer 210606 020  0501
   Coding: 00038805
   Shop #: WSC 00000
   Subsystem 2 - Part No: 1K0 955 559 AE  Labels: 1K0-955-559-AF.CLB
   Component: RLS     180606 014  1201
   Coding: 00208933
   Shop #: WSC 00000
1 Fault Found:
01504 - Bulb for License-Plate Light (X)
            012 - Electrical Fault in Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00101100
                    Fault Priority: 2
                    Fault Frequency: 3
                    Reset counter: 179
                    Mileage: 135542 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 11.95 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 T    HW: 1K0 909 605 T
   Component: 38 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD0KU66P
   Coding: 0013112
   Shop #: WSC 01269 785 00200
   VCID: 3D7B272D646A8F1
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 BC    HW: 1K0 953 549 BC
   Component: Lenksäulenmodul 035 0070
   Coding: 0000012
   VCID: 74EDC20917A00E9
1 Fault Found:
00888 - Wiper Switch for Intermittent Operation (E22)
            014 - Defective - Intermittent
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No SW: 1K6 920 963     HW: 1K6 920 963
   Component: KOMBIINSTRUMENT VDD 1610
   Revision: V0003000    Serial number: VWZ7Z0F8040446
   Coding: 0007403
   Shop #: WSC 80093 222 69422
   VCID: EFE74D65FE86AD1
Address 19: CAN Gateway        Labels: 1K0-907-530.lbl
   Part No SW: 1K0 907 530 H    HW: 1K0 907 951
   Component: J533__Gateway   H12 0150
   Revision:   H12       Serial number: 31001066240E74
   Coding: 7D0F074007000001
   VCID: 2C5D1A698F10169
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VDD 1610
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX3.lbl
   Part No SW: 1K0 959 701 N    HW: 1K0 959 701 N
   Component: Tuer-SG         005 0968
   Coding: 0000564
   VCID: 3973333D7042B31
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K2 909 144 L
   Component: EPS_ZFLS Kl.074 H07 1806
   Shop #: WSC 00000 028 00001
   VCID: 356B3F0D5C5A571
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 AJ
   Component:    KSG              0401
   Coding: 01C802087F2D840548DAC69010CC
   VCID: 78F5F6390BC86A9
   Part No: 1K0 951 605 B
   Component: LIN BACKUP HORN H07 7001
   Part No: 1K0 951 178
   Component: Neigungssensor  001 0101
   Component: Innenraumueberw.001 0101
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX3.lbl
   Part No SW: 1K0 959 702 N    HW: 1K0 959 702 N
   Coding: 0000820
   VCID: 3A712C317544B89
Address 55: Xenon Range        Labels: 1T0-907-357.lbl
   Part No: 1T0 907 357
   Component: Dynamische LWR      0003
   Coding: 0000003
   VCID: F4ED420997A08E9
Address 56: Radio        Labels: 1K0-035-1xx-56.lbl
   Part No: 1K0 035 186 R
   Component: Radio BVX       020 0032
   Coding: 0040402
Address 76: Park Assist        Labels: 1K0-919-283.lbl
   Part No: 1K0 919 283 A
   Component: 22 Einparkhilfe     0101
End   ---------------------------------------------------------------------
Offline jakex181
Re: Faults found help
« Reply #1 on: February 23, 2014, 03:22:47 pm »
Any ideas guys?
  • -Receive: 453
« Reply #2 on: February 23, 2014, 04:01:40 pm »
For the engine fault code would first try doing an intake  manifold runner basic setting
Prerequisites:
Ignition ON
 Engine OFF
 System voltage at least 11.0 V.
[Select]
[01 - Engine]
[Basic Settings - 04]
 Group 142
[Go!]
 Activate the Basic Setting.
[ON/OFF/Next]
 Wait until Field 4 shows "ADP. O.K.".
[Done, Go Back]
[Close Controller, Go Back - 06]
 Switch Ignition OFF for at least 60 seconds.
Offline jakex181
« Reply #3 on: February 23, 2014, 04:35:52 pm »
thanks mate i have just done it, shall i give it a week then rescan to see if this has fixed the issue?
  • -Receive: 453
« Reply #4 on: February 23, 2014, 04:54:32 pm »
If it comes back then I would think about changing the intake manifold motor to the latest version (06F133482E) as it's a known weak spot.
Offline jakex181
« Reply #5 on: February 23, 2014, 05:03:24 pm »
thanks for the help mate, any ideas about the window wiper intermittent switch?
Offline doylebros
  • -Receive: 310
« Reply #6 on: February 23, 2014, 05:43:37 pm »
Noticed this which may help you
http://www.ebay.co.uk/itm/06f-133-482-E-VW-AUDII-INTAKE-FLAP-MOTOR-BRAND-NEW-/161214954730?pt=Motors_Car_Truck_Parts_Accessories&hash=item258928fcea
Price new from VW dealers full retail inc vat £197.74
Offline doylebros
  • -Receive: 310
« Reply #7 on: February 23, 2014, 05:54:59 pm »
This is worth a read:-
http://forums.fourtitude.com/showthread.php?3878567-code-00888-help-(-Address-16-Steering-wheel-)
1K0 953 519 H 9B9 - switch for wipers/wash-wipe operation £65.82
1K0 953 519 J 9B9 - switch for wipers/wash-wipe operation & multi function indicator operation £70.58
Prices full retail inc vat
« Last Edit: February 23, 2014, 05:59:41 pm by doylebros »
Offline jakex181
« Reply #8 on: February 23, 2014, 06:58:45 pm »
is it the whole stalk that needs replacing then?
Offline doylebros
  • -Receive: 310
« Reply #9 on: February 23, 2014, 07:02:03 pm »
That's what the link says but to be sure you can check it with VCDS tool in advanced measuring blocks
This link is a list of people who offer that service
http://www.mk5golfgti.co.uk/forum/index.php/topic,120.0.html
See if anyone is close to you?
Offline jakex181
« Reply #10 on: February 23, 2014, 07:04:38 pm »
i have vcds but wouldnt be confident without a guide if you know of one?
Offline doylebros
  • -Receive: 310
« Reply #11 on: February 23, 2014, 07:42:50 pm »
 It's one of those tools you use to learn.
It would take to long to write it all down - basically it's in the safe section so you can't do any harm.
Offline doylebros
  • -Receive: 310
« Reply #12 on: February 23, 2014, 07:50:07 pm »
« Last Edit: February 23, 2014, 07:52:12 pm by doylebros »
Offline jakex181
« Reply #13 on: February 23, 2014, 07:52:34 pm »
Ive just messages the seller :) great timing
Offline jakex181
« Reply #14 on: February 24, 2014, 05:15:19 pm »
i just carried out the measure value blocks with vagcom and the window wiper switch seems to work fine, it shows the stage changing as i use the switch but the fault is still coming up when i scan :/ any ideas?
