Author Topic: Faults found help  (Read 5508 times)
Offline doylebros
  • -Receive: 310
Re: Faults found help
« Reply #15 on: February 24, 2014, 05:17:48 pm »
Clear the DTCS. For that module then redo the measuring block testes then an output test and see if the faults still there.
Offline reaper7881
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,68492
« Reply #16 on: February 24, 2014, 06:20:28 pm »
Does your car have a rain light sensor
54 MK5 Golf 1.9tdi 3dr SMD Full Interior and Speedo Conversion, GTi Highline , Flat Bottom Wheel, ED30 Rear lights
Offline jakex181
« Reply #17 on: February 24, 2014, 06:26:15 pm »
yeah the car has a rain light sensor as it has auto wipers and headlights
Offline jakex181
« Reply #18 on: February 25, 2014, 01:06:44 pm »
I have noticed that sometimes ill put the auto wipers on and they will be going crazy even with the smalled bit of rain and I adjusting the sensitivity does nothing, does this prove its the switch?
Offline doylebros
  • -Receive: 310
« Reply #19 on: February 25, 2014, 03:30:15 pm »
My thought would still be with the switch - dealer says they sells more switches than rain sensors!
Offline jakex181
« Reply #20 on: February 25, 2014, 05:56:35 pm »
Ive got a new switch on the way, do i have to remove the steering wheel to replace it? i hope not! :/
Offline jakex181
« Reply #21 on: February 26, 2014, 12:02:31 pm »
Is there a way to actually test the intake runner control using vagcom?
Offline doylebros
  • -Receive: 310
« Reply #22 on: February 26, 2014, 03:44:27 pm »
  • -Receive: 453
« Reply #23 on: February 26, 2014, 04:30:07 pm »
Yes, you can do the output test.
open vcds>engine>output test 03
then select Intake manifold flap from the drop down list
While the test is running the actuator arm should move to fully open and close the flaps
