Author Topic: vag not replacing parts on service  (Read 2965 times)
Offline south
« on: February 27, 2014, 05:13:22 pm »
Major service 5k ago. What's that VW? You changed the plugs for me as part of the service? Ah, brilliant!
Offline richtung
  • -Receive: 56
Re: vag not replacing parts on service
« Reply #1 on: February 27, 2014, 06:26:49 pm »
You dont state what mileage your car was on when it was serviced.  To be fair to the dealers, the spark plugs aren't due to be replaced until 60k miles on the GTI..
Rich
Offline south
« Reply #2 on: February 27, 2014, 07:44:24 pm »
just turned over to 65, was down on the last invoice as having been changed... best £35 I've spent on the car so far!
Offline Markyed30
« Reply #3 on: February 27, 2014, 08:25:11 pm »
I have very little faith with any mechanics as this is rife  :sad1:
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
« Reply #4 on: February 27, 2014, 08:50:40 pm »
How does this prove they didn't change them? Why is it not possible that the plugs could look like this after 5k miles? :confused:
'07 Red manual
Offline south
« Reply #5 on: February 27, 2014, 08:57:10 pm »
I'll bite... apart from the fact I had the same issue with a polo before (major service, checked plugs 2 weeks later) everything else on the engine is impeccable, even the rev B DV valve I changed last weekend was fine. 2-3mm of carbon around the plug end in 5k, really?!?! From what I've read dealer estimates for life of a plug range from 40-60k, how many average Joes' are gonna bother checking the spark plugs after a service? Easy way to skimp on £40~ for a dealer.
Offline south
« Reply #6 on: February 27, 2014, 08:59:02 pm »
In fact I'll tell you what, I'll run the car another 5k and try and remember to post up a picture of the plugs after that... if they're as messed up as that I won't eat my hat, I won't be able to with the forthcoming repair bill.
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
« Reply #7 on: February 27, 2014, 09:16:30 pm »
Why on earth would you return to this dealer?
As I'm no expert I'm hoping someone can prove beyond doubt that the plugs could not be in this condition after 5k miles.
'07 Red manual
Offline south
« Reply #8 on: February 27, 2014, 09:17:47 pm »
Different dealership, I'm not quite that dumb... yet(!)
Offline garrardrj
  • -Given: 76
  • -Receive: 42
« Reply #9 on: February 27, 2014, 09:18:10 pm »
Why did you check the plugs ? If they were changed 5000 miles earlier and don't need doing until another 55000 miles ? Why did you check the Polos plugs too ? Seems quite an odd thing to do ? :innocent:
If you think that the Plugs were not replaced i would be straight down to the place that had done them and questioned them about it , rather than grizzling on here about it . If you think that a main dealer would charge for replacing the plugs and didn't you don't really know the motor trade well .
I am sure that the plugs could look like this after 5000 miles too
« Last Edit: February 27, 2014, 09:20:49 pm by garrardrj »
Offline xjay1337
  • -Receive: 377
« Reply #10 on: February 27, 2014, 09:27:07 pm »
I always ask for the old parts back... or mark them if you really want to be anal.
Then again, if you're that anal, why not change them yourself... save a bunch of cash...
Offline south
« Reply #11 on: February 27, 2014, 09:32:59 pm »
Thanks for the patronising reply garrardrj, last service was done by previous owner. Changed because of a rough idle and appalling mpg, improved hugely since.
@xjay - really good idea, will bear that in mind. I have taken as much of a DIY approach to the things I can change myself as I can.
Offline Itsagthing
« Reply #12 on: February 27, 2014, 09:40:57 pm »
Plugs can look like that after 5k miles, the carbon build up is from other issues with an individual engine not just spark plug looks after 5k miles. Plugs are generally advised every 60k ish on most manufacturers, if your engine had an issue with it and a set of plugs were thrown in and "seemed" to cure the problem (rough idle etc)  yet looked like that again after 5k miles then sir you have other issues with your engine! Not necessarily the dealer/ technicians fault. My 2pence worth. :congrats:
Offline south
« Reply #13 on: February 27, 2014, 09:43:48 pm »
^pretty much, will check after another 5k... trying not to think about the consequences of the later!
Offline SRC
  • -Receive: 27
« Reply #14 on: February 28, 2014, 10:32:12 am »
Garrardrj has been on this forum a while.  Although I don't know him, his post didn't seem patronising to me.  After all, you've posted on an internet forum - you've invited opinions.
FWIW, I think he might be right.  If the plugs look old / the car's running rough or whatever a car's fault may be, the chances are that blame may lie elsewhere than at the dealer's door.
I hope you don't think I'm being patronising, too.  I like balance is all.
Shadow blue DSG 5 door with leather, sunroof, 18" Monzas, MFSW.
Full list of mods:  Seat inserts and a VW bottle opener.  Each worth 20bhp.
