Author Topic: favor needed !! shorted cigar lighter then messed up fuses now limp mode!  (Read 5658 times)
Offline doylebros
  • -Receive: 310
Re: favor needed !!
« Reply #15 on: March 01, 2014, 10:26:43 pm »
i bet its the fuse for whateva p2294 is lol i must have messed that one up too!
This is worth a read
http://www.vwaudiforum.co.uk/forum/showthread.php?146821-fuel-pressure-regulator-p2294-epc
Offline alexharvey
Re: favor needed !!
« Reply #16 on: March 01, 2014, 11:00:43 pm »
I've sorted that bit out now just the rest of car don't work lol lol cigar lighter is cool thanks tho
Offline alexharvey
Re: favor needed !!
« Reply #17 on: March 01, 2014, 11:18:05 pm »
Sounds like what I have done but I'm sure I checked them but that's according to Haynes Manuel etc so few was diff
Need to see or get fuse plan for 05 car !!!! I. Sure dealer will say replace fuel pump lol
Offline brookesb32
  • -Given: 59
  • -Receive: 75
Re: favor needed !!
« Reply #18 on: March 02, 2014, 07:13:19 pm »
hi all,
posting for Alex as I have the scans. We met up and plugged the VCDS in and after clearing the codes in the car these were left the second time around. We also checked the fuses we could think of and seem to be correct and not blown.
Ignore the door ones as he has a broken indicator so throwing up those faults.
Strange ones are highlighted - not sure what the radio ones could be. We had to bump start the car as it wouldn't start after the scanning, so wondering if something is draining the battery - perhaps the brake light switch which could be the cause of the implausible brake fault?
anyway, the EPC and engine light are still on so seems to be in limp mode
he really needs some helps chaps if you could rack your brains on this!  :drinking:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 76
VIN: WVWZZZ1KZ5W247022   Mileage: 139200km/86494miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 1010
76-Park Assist -- Status: OK 0000
Address 01: Engine        Labels: 06F-907-115-AXX.lbl
   Part No SW: 1K0 907 115     HW: 1K0 907 115
   Component: 2.0l R4/4V TFSI  00 0070
   Revision: --H01---    Serial number: VWZ7Z0E2056673
   Coding: 0403000318070060
   Shop #: WSC 00025 210 88127
   VCID: E3C5D0D922F21506665-80B6
3 Faults Found:
008852 - Fuel Pressure Regulator Valve (N276)
               P2294 - 004 - Open Circuit - MIL ON
             Freeze Frame:
                    Fault Status: 11100100
                    Fault Priority: 0
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 0 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 226 /min
                    Load: 67.4 %
                    Speed: 0.0 km/h
                    Temperature: 66.0°C
                    Temperature: 41.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 9.779 V
005634 - Power Supply Terminal 30
               P1602 - 002 - Voltage too Low - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 0
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 0 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: -40.0°C
                    Absolute Pres.: 0.0 mbar
                    Voltage: 0.000 V
001393 - Brake Switch (F)
               P0571 - 008 - Implausible Signal
             Freeze Frame:
                    Fault Status: 01101000
                    Fault Priority: 0
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 139092 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 00:06:05
             Freeze Frame:
                    RPM: 1624 /min
                    Load: 12.5 %
                    Speed: 43.0 km/h
                    Temperature: 72.0°C
                    Temperature: 24.0°C
                    Absolute Pres.: 980.0 mbar
                    Voltage: 13.970 V
Readiness: 0000 0000
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No: 1K0 907 379 K
   Component: ESP FRONT MK60      0104
   Coding: 0004738
   Shop #: WSC 01279 785 00200
   VCID: 3A7BCDBD75F8B4CE953-806F
No fault code found.
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No: 1K0 907 044 AF
   Component: ClimatronicPQ35 066 0505
   Shop #: WSC 00000 000 00000
   VCID: 6BD538F94A22DD465E5-803E
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 1K0 937 049 N    HW: 1K0 937 049 N*
   Component: Bordnetz-SG     H37 0803
   Revision: 00H37000    Serial number: 00000001812426
   Coding: E58D0F0600041800001400001400000000087F075C
   Subsystem 1 - Part No: 1K2 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  012  0401
   Coding: 00065493
   Shop #: WSC 00000
   Subsystem 2 - Part No: 1K0 955 559 R  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 010  1010
   Coding: 00207646
   Shop #: WSC 00000
1 Fault Found:
01800 - Light Switch (E1)
            008 - Implausible Signal - Intermittent
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 N    HW: 1K0 909 605 N
   Component: 08 AIRBAG VW8   015 2100
   Revision: 03015000    Serial number: 0038ED0CJKEH
   Coding: 0012344
   Shop #: WSC 01269 785 00200
   VCID: 377DD48946EAA9A66AD-8062
   Subsystem 1 - Serial number: 6332MSME0A0D5944G
   Subsystem 2 - Serial number: 6342MSME090B5834C
   Subsystem 3 - Serial number: 6351HSME067F4D59Q
   Subsystem 4 - Serial number: 6361HSME066B524BD
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 F    HW: 1K0 953 549 F
   Component: Lenksäulenmodul 521 0050
   Coding: 0000012
   VCID: 3561DE815CE65BB6781-8060
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No: 1K6 920 960 D
   Component: KOMBIINSTRUMENT VDD 0812
   Coding: 0003403
   Shop #: WSC 25052 210 94111
   VCID: 306FEF95A3847E9E2B7-8065
Address 19: CAN Gateway        Labels: 1K0-907-530-V1.clb
   Part No SW: 1K0 907 530 E    HW: 1K0 907 951
   Component: Gateway         H11 0110
   Revision: 11          Serial number: 29001054231089
   Coding: 3D0F0740070001
   VCID: 295902F1805E0F56EC9-807C
2 Faults Found:
01305 - Databus for Infotainment
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 1
                    Fault Frequency: 3
                    Reset counter: 4
                    Mileage: 139209 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 19:32:08
01304 - Radio
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 3
                    Reset counter: 4
                    Mileage: 139209 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 19:32:13
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VDD 0812
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX1.lbl
   Part No: 1K0 959 701 G
   Component: Tuersteuergeraet 09 0118
   Coding: 0000054
   VCID: 326BE59DAD884C8E5D3-8067
1 Fault Found:
00131 - Outside Door Handle Illumination/mirror Light Driver Side
            012 - Electrical Fault in Circuit
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K2 909 144 H
   Component: EPS_ZFLS Kl.12      1502
   VCID: 3169EA91A88E7796249-8064
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 AJ
   Component:    KSG              0401
   Coding: 01C802087F2D8505485AC69010CC
   Shop #: WSC 01287 785 00200
   VCID: 78FF17B50B7466DEA37-802D
   Subsystem 1 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HORN H02 1301
   Subsystem 2 - Part No: 1K0 907 719 B
   Component: Neigungssensor  004 0003
   Subsystem 3 - Part No: 1K0 951 177 A
   Component: Innenraumueberw.005 0202
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX1.lbl
   Part No: 1K0 959 702 G
   Coding: 0000054
   VCID: 3365E09952924586565-8066
1 Fault Found:
00132 - Outside Door Handle Illumination/mirror Light Passenger Side
Address 56: Radio        Labels: 1K0-035-1xx-56.lbl
   Part No: 1K0 035 186 L
   Component: Radio BVX       014 0022
   Coding: 0040400
   VCID: 2F6DECE9BEBA616632D-807A
2 Faults Found:
00003 - Control Module
            014 - Defective
00849 - S-contact at Ignition/Starter Switch (D)
Address 76: Park Assist        Labels: 1K0-919-283.lbl
   Part No: 1K0 919 283 A
   Component: 01 Einparkhilfe     0101
   VCID: 2D51F6E1B4B61376001-8078
End   ---------------------------------------------------------------------
Offline alexharvey
thanks for posting mate !!
and thanks for the help today
Offline brookesb32
  • -Given: 59
  • -Receive: 75
Happy to help, hopefully an easy fix  :happy2:
Offline alexharvey
hope so too !
i will check battery tom morn!!!
if starts will check on battery meter!
cant handle limp mode for much lonegr lol
Offline doylebros
  • -Receive: 310
To understand the results I assume you managed to have this running?
Where any of the fuses checked in the engine bay?
Offline brookesb32
  • -Given: 59
  • -Receive: 75
I was scanning without the car turning over - not sure if better to have had the engine on rather than just ignition? We did check the engine bay and that's where we noticed the radio fuse in wrong place (see thread in vcds section) and also that a 5a fuse rather than 15a in the spot for the fuel pressure sensor - however fuse was absolutely fine and not blown and same scan results after the change
Offline doylebros
  • -Receive: 310
My thoughts is the battery is so low the reading are being corrupted.
If he wasn't suffering battery drain prior his Hoover issue I would be looking at the charging circuit - did you check to see what it was charging at after you managed to jump start it?
How is the battery being charged now,so that It has a chance to start in the morning?
Offline brookesb32
  • -Given: 59
  • -Receive: 75
I didn't look to be honest, we were just to get it started - had to bump him down the steakhouse car park  :smiley:
Offline doylebros
  • -Receive: 310
This post may help since the brake lights are stuck on
http://www.mk5golfgti.co.uk/forum/index.php/topic,79591.msg827583.html#msg827583
