Author Topic: heated mirrors not working. golf gti mk5  (Read 13138 times)
Offline raznutz
« on: March 04, 2014, 07:59:43 am »
Hi
My heated mirrors not working.
Any ideas how to check we're to start. It's a golf gti mk5..... :happy2:
Offline SI-R32
  • -Receive: 126
Re:
« Reply #1 on: March 04, 2014, 08:42:20 am »
Hate to state the obvious, but a lot of people think there attached to the rear window, but the heat setting is on the mirror switch, are you aware of this?
Offline raznutz
Re: heated mirrors not working. golf gti mk5
« Reply #2 on: March 04, 2014, 08:52:02 am »
yes mate
its been on the on the centre (o) since ive own the car,will that make any difference..
Offline raznutz
« Reply #3 on: March 04, 2014, 08:52:45 am »
is there any fuses for it..or diagrams
Offline SI-R32
  • -Receive: 126
Re:
« Reply #4 on: March 04, 2014, 08:55:29 am »
You need to flick it round to the little heat symbol. At the top of the switch have a close look and you'll see it, loads of people mis it
Offline raznutz
« Reply #5 on: March 04, 2014, 08:59:03 am »
on the mirror adjuster theres a simble of a heated mirro sign ,mine is on that already and its still not working..
Offline SI-R32
  • -Receive: 126
Re:
« Reply #6 on: March 04, 2014, 09:03:47 am »
Oh right sorry thought you said its on the centre position,  anyway both heated glasses are controlled via the window modules, if all other things in the doors are working, no fuses are blown.
First thing I'd do is pop a glass off and measure voltage on them,  with engine running,  if no voltage then perhaps try another switch, there might be a minimum temp that that work at so it needs to be quite cold first
Offline raznutz
« Reply #7 on: March 04, 2014, 09:55:52 am »
Ok cool
Offline raznutz
« Reply #8 on: March 04, 2014, 10:05:46 am »
Just thinking can I take the switch out to test or not
Offline raznutz
« Reply #9 on: March 04, 2014, 10:12:33 am »
or i nned to take panel of
Offline raznutz
« Reply #10 on: March 04, 2014, 10:12:54 am »
or i need to take panel of
Offline jbenekeorr
« Reply #11 on: March 04, 2014, 07:59:17 pm »
I think from memory it has to be 10 degrees or less for them to work.
Not much danger of it being above that much at the minute!
Offline raznutz
« Reply #12 on: March 13, 2014, 07:54:58 am »
Hi
I've changed the switch. And today was a good time to check it worked as it is foggy . but it still don't work.any things else it can be..?
Offline raznutz
« Reply #13 on: March 13, 2014, 08:43:42 am »
hi
is there a fuse for it if so could anyone show me please.thanks
Offline jonm
    • Staffs-VW
« Reply #14 on: September 06, 2017, 08:26:22 pm »
anyone find the fix for this? the drivers side on mine has gone!
