Author Topic: Drivers side window breaking, bad noise  (Read 711 times)
Offline Combatwombat50
« on: April 24, 2014, 06:59:43 pm »
My drivers side window sounds like it's breaking, it's fine wen lowering the window, but when raising it up there is an awful crunching noise from inside the door, and when the window nearly gets to the top it will lower itself until I hold the button to raise it fully and even then it does now seal properly, anyone any ideas what it could be?? Friend says it could be the motor on it's way out, if this is the case would a new motor solve it or would I need a new regulator aswell??
Chris
