Author Topic: ecu locked out  (Read 3701 times)
Offline Sandbagsniper
ecu locked out
« on: April 26, 2014, 12:30:54 pm »
I put my car into Star Performance for brakes and suspension upgrades. I had them fit a new pcv, then they were to drop a stage 1 onto my otherwise standard gti. I was told that my ecu is locked. They suggested that perhaps a previous owner had a free trial. How do I get my ecu unlocked? I have no idea who locked the ecu. The car is currently running standard boost.
  • -Receive: 453
Re: ecu locked out
« Reply #1 on: April 26, 2014, 02:33:45 pm »
My understanding is you need to get the ecu reflashed with the standard vw software then go from there.
Re: ecu locked out
« Reply #2 on: May 10, 2014, 03:51:27 pm »
The manufacturer are not "locked out", however to get VW to flash will probably cost.
Try your nearest Revo dealer just say you think it's had a trial at some stage and you want it flashed back to stock.
I'm surprised Star can't tell you who has mapped your car.
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
Re: ecu locked out
« Reply #3 on: May 10, 2014, 09:13:00 pm »
If the ECU is locked then they can't read the map so couldn't say who's software it is. Likely candidates are Revo, APR or GIAC. I had the same issue with my Leon, turns out I had Revo Stage 1 software on there, but set back to the 'standard performance'. Revo should be able to tell you if you give them your VIN, not sure what kind of records/details anyone else would need
Offline twalters
Re: ecu locked out
« Reply #4 on: May 10, 2014, 09:59:32 pm »
I can re flash standard software onto these ecus.
pm if its still needed.
Offline Markyed30
Re: ecu locked out
« Reply #5 on: July 04, 2014, 08:05:12 pm »
Have you got cruise control you may have a stage 1 apr map already there but someone has set it to stock map how class would that be!!!!
