Author Topic: What happens if I remove my cluster?  (Read 2240 times)
Offline J12spk
  • VW PERVERT
« on: May 05, 2014, 09:37:13 pm »
Hey all, planning on fitting a rear view cam later this week and when I run the cable to the head unit I wana run it behind the cluster. If I remove the cluster will I get any faults or any problems that I will need vcds when I reinstall it?
James
Das Auto
Offline Pikey Motorsports
Re: What happens if I remove my cluster?
« Reply #1 on: May 05, 2014, 09:41:01 pm »
Not as far as i can remember
TSR PERFORMANCE GTX30 520BHP
LITCHFIELD R35 GT-R 660BHP
MSL E63 AMG 720BHP
HCP BM3 M5 800BHP
Offline mvb12
  • -Receive: 64
« Reply #2 on: May 05, 2014, 10:48:19 pm »
Nothing I believe. Had mjne out before and no need for vaggy.
Offline mvb12
  • -Receive: 64
« Reply #3 on: May 05, 2014, 10:48:40 pm »
Nothing I believe. Had mine out before and no need for vaggy.
Offline GTI-Pirelli
  • -Receive: 27
« Reply #4 on: May 05, 2014, 10:57:16 pm »
I don't know for sure but I would avoid the temptation to turn the ignition on without the cluster connected.
I say this as I once fitted a USB adaptor to my head unit in my last MK5. I tried it out before putting the dash back together. The Airbag warning light came on as I hadn't reconnected the passenger warning light above the air vents. It had to be cleared with VAGCOM as Airbag fault don't self reset.
Having the cluster disconnected might also trigger it as the warning light is in there!
2017 Audi S4
Offline xjay1337
  • -Receive: 377
« Reply #5 on: May 05, 2014, 11:50:12 pm »
You should be able to remove your cluster and plug it back in fine.
Not sure why you'd want to though.
If you plug another in then you'd need to code it.
Jairm converted his dash to white backlit and popped it out without any worry and no issues with his.
Offline J12spk
  • VW PERVERT
« Reply #6 on: May 06, 2014, 09:31:28 am »
So you don't know why I wana remove my cluster Jay and Silent Bob, did you actually read the thread or just the title then reply? I wana run the cable for the cam behind it!
 :stupid:
Das Auto
Offline xjay1337
  • -Receive: 377
« Reply #7 on: May 06, 2014, 02:08:35 pm »
Oh, well next time i'll not bother to try to help out and spend the time i have reading instead.  :happy2:
Offline J12spk
  • VW PERVERT
« Reply #8 on: May 06, 2014, 02:30:30 pm »
Surely it takes seconds to read then tailor your reply to the needs of the request?  :signLOL: :happy2:
Das Auto
Offline stuart-88
  • -Receive: 21
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,101197.0.html
« Reply #9 on: May 06, 2014, 06:50:54 pm »
We disconnected the battery each time it was removed though.
Instagram: stu_nc88
Offline biffobear
« Reply #10 on: May 06, 2014, 06:52:41 pm »
 :stupid:
why :rolleye:
Offline J12spk
  • VW PERVERT
« Reply #11 on: May 06, 2014, 08:29:07 pm »
 :stupid:
why :rolleye:
Das Auto
Offline biffobear
« Reply #12 on: May 06, 2014, 09:08:54 pm »
Why? Its like saying "I need to run some cable through the bulkhead, so I will take the engine out to make it easier"
Offline J12spk
  • VW PERVERT
« Reply #13 on: May 06, 2014, 09:09:44 pm »
 :congrats:
Das Auto
Offline doylebros
  • -Receive: 310
« Reply #14 on: May 06, 2014, 09:13:47 pm »
Why worry, you need to do the coding for the camera so still need VCDS!
