Author Topic: turbo  (Read 1073 times)
Offline CRAZY CATH
turbo
« on: May 15, 2014, 07:29:27 pm »
any one know how long it should take to remove the turbo from a 140 gt tdi 2005
Offline SurreyED30
Re: turbo
« Reply #1 on: May 15, 2014, 07:33:03 pm »
Depends on how much knowledge you have and how good you are with tools ?
May take someone 2 hours and others 2 days lol
Offline CRAZY CATH
Re: turbo
« Reply #2 on: May 15, 2014, 07:41:38 pm »
thanks for the reply 2.5 to 3 it should be then
Offline SurreyED30
Re: turbo
« Reply #3 on: May 15, 2014, 07:43:09 pm »
Good with tools then  :happy2:, isn't broken is it? Or just checking it over  :innocent:
Offline CRAZY CATH
Re: turbo
« Reply #4 on: May 15, 2014, 08:20:06 pm »
not broken as such keep getting overbost pretty sure its coked up so off it will come and have a nice bath
Offline SurreyED30
Re: turbo
« Reply #5 on: May 15, 2014, 08:22:44 pm »
Can't beat a bit of tlc  :smiley:
Offline doylebros
  • -Receive: 310
Re: turbo
« Reply #6 on: May 15, 2014, 09:17:26 pm »
If you remove the drive shaft it's a simple enough job 3-4 hours if you want to enjoy it!
However, if you've got that fault I suggest replacing the oil feed pipe (cause too may get choked up and bearing failure typically follows that fault).
