Author Topic: 0-60 timer  (Read 4179 times)
Re: 0-60 timer
« Reply #15 on: May 16, 2014, 04:37:19 pm »
Polar FIS+ uses the speed/rpms from the car to calculate the 0-60
Dynolicious uses the accelerometer/gyro in the Ipad/Iphone to calculate acceleration
VI Monitor does the same as the Polar FIS+
Racelogic VBox uses GPS and was proven to be very accurate when comparing to a £30k F1 datalogging GPS system.
Dynolicious is fairly accurate as long as you accelerate on one level, if the level changes it becomes more inaccurate.
Offline Jussa
  • Bicester
Re: 0-60 timer
« Reply #16 on: May 16, 2014, 06:50:15 pm »
John, are u saying that the VI monitor only goes by the speedo speed??  :surprised:
Because 60 on the speedo is nowhere near the correct speed.
Offline mvb12
  • -Receive: 64
Re: 0-60 timer
« Reply #17 on: May 16, 2014, 06:52:36 pm »
How do you do this I have a private road or 2 to have a play.
You need to go into the configuration menu by long press of ok on a polar desktop>Chromometer>ok
Acceleration - ok
Start Speed - ok
Set Speed using + and -
Stop Speed
Start - ok
Note: start speed needs to be set at 1MPH otherwise the timer will start as soon as you hit start rather than as soon as the vehicle moves.
Thanks to neg for the how to.
nice one mate  :happy2:
Re: 0-60 timer
« Reply #18 on: May 17, 2014, 08:45:56 am »
It goes by engine speed in rpm off the OBD information. Slightly more accurate than the speedo, but still not as accurate as GPS.
Offline dan930
  • -Receive: 56
Re: 0-60 timer
« Reply #19 on: May 17, 2014, 11:47:30 am »
What do u mean by accelerate on one level?
MK6 golfR dsg
AKS TUNED
NORTECH PERFORMANCE HTA3071
R TECH custom map
  • -Receive: 453
Re: 0-60 timer
« Reply #20 on: May 17, 2014, 12:02:09 pm »
You need to be doing the run on a flat road with no uphill or downhill segments.   :smiley:
Offline dan930
  • -Receive: 56
Re: 0-60 timer
« Reply #21 on: May 17, 2014, 02:29:09 pm »
Cheers mate :happy2:
MK6 golfR dsg
AKS TUNED
R TECH custom map
Offline GunnerGibson
Re: 0-60 timer
« Reply #22 on: May 17, 2014, 11:17:51 pm »
Android Torque App seems a good price and packed with features...
