Author Topic: How long should rear shocks last? My ride is really crashy - Help?  (Read 1735 times)
Offline GTI-Ross
  • Learning All The Time :)
How long roughly should rear shocks last, I know it depends on type of road you have driven on, but just a rough idea. My ride has become very crashy and stiff feeling, like the springs are not compressing properly, I thought shocks always went soft rather than hard when failing?
I do have uprated roll bars, but still, the ride when going over bumps can be very harsh. And sometime it sounds like my boot is open. But its fully shut and no movement at all.
MK6 GTI with 55k on the clock.
Any ideas?
« Last Edit: June 09, 2014, 07:38:11 pm by GTI-Ross »
Offline OEM+ DUB
Re: How long should rear shocks last? My ride is really crashy - Help?
« Reply #1 on: June 09, 2014, 08:21:51 pm »
Hi there
Just an idea for a simple thing to check but have you checked the rear springs for snapped coils/fractures?  If you have a snapped coil the car can ride poorly as the spring can't compress normally.
Hope this helps!
OEM+ 2005 GTI DSG (high factory standard spec and upgraded with S3 alloy hubs, S3 alloy wishbones, Bilstein B8s and VWR springs by my own hands) owned since 2008 and still loving it!
Offline GTI-Ross
« Reply #2 on: June 09, 2014, 08:40:42 pm »
No i think both springs are fine, think im gonna take the shocks out and compress them and see how fast they return to normal position.
Offline OEM+ DUB
« Reply #3 on: June 09, 2014, 10:38:12 pm »
Fingers crossed then that it's a simple fix.  General rule of thumb is that shocks are often past their best when you get beyond 50k as they have a hard life - the rears inparticular.
Offline GTI-Ross
« Reply #4 on: June 09, 2014, 10:52:40 pm »
I know, but usually they go soft and sloppy, not hard and stiff. I just cant see it being the roll bard that has made it this stiff, even a small bump can be harsh
Offline Llew
  • -Given: 45
« Reply #5 on: June 18, 2014, 10:41:20 pm »
Did you resolve this?
Golf 2006 tdi 140pd, dsg paddles,blue interior led lights,r32 rear bumper, cruise control,vcds,highline , r32 mfsw steering wheel, gti front bumper,miltek decat.
Offline GTI-Ross
« Reply #6 on: June 19, 2014, 10:50:50 pm »
funnily enough they sorted them self's, not sure if washing my aches with pressure washer made them seize temporally. seem fine now  :driver:
