Author Topic: Just making sure i'm right before ordering  (Read 800 times)
Offline CarlW
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,92229.msg927100.html#msg927100
« on: June 18, 2014, 09:16:02 pm »
I've lifted the engine cover off as it was sat wrong meaning a panel of the air intake has fell off and been lost again..
After lifting the cover off i've noticed some cowboy has at some point replaced some bits under the engine cover being.. miss matching engine cover mounts (ball points), also only one rubber grommet which is no is of no use along with a bit of silicone pipe which seems to have replaced a ball point and grommet.. :surprised:
I'd like to resolve this little problem and replace all the engine cover mounts (ball points) along with 4 new rubber grommets.
Just want to check if i have the right part numbers.
Ball points: WHT 000 898
Rubber grommets: 036129689B
Also do i need anything else like screws or any kind of retaining plates?..
Thanks,
Carl.
  • -Receive: 453
Re: Just making sure i'm right before ordering
« Reply #1 on: June 18, 2014, 09:26:19 pm »
Those numbers are correct but be aware that you'll need a deep socket to tighten those ball points without damaging them.
Offline CarlW
« Reply #2 on: June 18, 2014, 09:44:01 pm »
Okay, thanks bacillus
