Author Topic: VW RNS510 Version B?  (Read 1201 times)
Offline MJGib
  • -Given: 22
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,85702
« on: June 26, 2014, 08:26:16 pm »
Iv got a basic mk5 golf gti
Isit straight plug & play?
Will the sat nav work or do I need to change the ariel?
Your knowledge would be greatful, thanks :-)
MK5 Golf GTI: K04 converted stage 2+ (I don't own this car no more)
Insta - gibs94_
Offline Viking
  • -Given: 17
  • -Receive: 47
Re: VW RNS510 Version B?
« Reply #1 on: June 26, 2014, 08:34:57 pm »
You'll need a GPS antenna puck, and an aerial adaptor to make it fit. Then there'll be some coding with VCDS to make everything work. Then you'll need to change the CAN gateway to prevent battery drain issues, or modify the firmware on the RNS510 for the same reason.
Sarcasm for free. Anything after that can only be considered as a bonus.
Just because you think you know something, doesn't make you an expert if you've just read it on the internet, y'know.
Offline MJGib
  • -Given: 22
« Reply #2 on: June 26, 2014, 08:37:23 pm »
Thank you very much :-)
Insta - gibs94_
