Author Topic: Steel Grey & Plasti Dipped Monza's?  (Read 4322 times)
Offline Jomty
« on: August 05, 2014, 10:48:41 am »
Hi guy's,
Apologies if this is in the wrong place. I'm trying to find a picture of a steel grey GTi with plasti-dipped 18" Monza's. Also do you ruin the finish of the alloy in the spraying process? Im contemplating doing it to mine as they are white worming (not too bad), but enough for me to look at doing something with them.
Thanks.
Offline burger187
Re: Steel Grey & Plasti Dipped Monza's?
« Reply #1 on: August 05, 2014, 06:37:59 pm »
Hi guy's,
Thanks.
plasti dip is a quick and easy option to do, if u don't like it peel it off. I have mine done in Matt black on a black car
Offline Jomty
« Reply #2 on: August 05, 2014, 07:12:08 pm »
How did you do it, is it a case of clean the wheels and spray on? Yeah they look smart on black, can't find any bloody pictures on grey though.
Offline Bennz
« Reply #3 on: August 06, 2014, 12:26:00 am »
I would be keen to know and see how's it's done and the finished result. Been thinking about steel grey myself . My 17 inch factory one is painted silver and my car is white. A bit of darker color wheels would look nicer :)
Offline burger187
« Reply #4 on: August 06, 2014, 07:11:51 am »
yep, make sure the wheels. U don't have to remove the wheels from the car , cover the brakes discs with plastic bags. First layer should be a light one. Do about 5 layers, as for cleaning them u have to becarefull. Don't use no chemicals just water and soap or a pressure washer. There's a video on YouTube on how to do it
Offline Jomty
« Reply #5 on: August 06, 2014, 07:14:52 am »
I checked out a couple of youtube vidoe's last night and it seems pretty easy. The channel was "Dip Your Car". They where doing all sorts of stuff with it. Still can't find a steel grey GTi with black monza's on it though, maybe it looks sh*te.  :signLOL:
Offline burger187
« Reply #6 on: August 06, 2014, 07:18:39 am »
yep that's the main channel, he done a while golf gti in plastidip lol. Tbh I don't think
Grey with black alloys would go, I would do grey with gold metalizer
Offline Bennz
« Reply #7 on: August 06, 2014, 07:33:34 am »
I think Anthracite Grey is good mixture of dark but shiny color. Has anyone tried this color ?
So if someone wants more metallic, do you mix them while painting or the shine layer after the base layer?
Offline Jomty
« Reply #8 on: August 06, 2014, 07:34:47 am »
That, I hadn't thought about, and I bet it would look good, thanks for the idea!
Offline Jomty
« Reply #9 on: August 06, 2014, 07:42:07 am »
Just been on the plasti dip UK website, you spray the base layer on and allow it to dry, then put as many coats of the metalizer spary on as you like to get the finish you want. Roll on pay-day  :drinking:
Offline Bennz
« Reply #10 on: August 06, 2014, 08:02:56 am »
Yep and can use glossifier on the grey as well. Watched video of a guy using both on his 370z and the result looks good ! Dark but shiny as well :)
Offline Jomty
« Reply #11 on: August 06, 2014, 08:26:04 am »
Hmm, so from the website it's gonna cost about £100 for all the stuff. That's with 1 can of grey primer (Poss need 2?), 4 cans of the gun metal grey and 2 cans of metalizer... Is this over-kill? I thought it was gonna be a relatively cheap job, another 100 and I could just get them powder coated!  :confused:
Offline Bennz
« Reply #12 on: August 06, 2014, 08:43:43 am »
Do you need the primer? The gun metal should be good , I read if wheels are small 2 or max 3 bottles are enough for couple of layers of it on each wheel
Offline Jomty
« Reply #13 on: August 06, 2014, 08:52:07 am »
When I've looked it says to use the primer, but the video I watched last night he didn't use it, so you could probably get away without I think.
Offline burger187
« Reply #14 on: August 06, 2014, 03:51:15 pm »
u do a black base coat and do the metallic on top of the base coats once dried
