Author Topic: Rcd510 need answer asap please  (Read 1248 times)
Offline K9
  • VW LifeStyle
« on: August 19, 2014, 09:06:17 pm »
 :scared: hey, i'm bout to order a rcd510 oem from ebay and will be changing from a rcd300 -> rcd510. the golf gti is a 2005.
question is now that what gateway do i need to order and from where to avoide battery drain? can it be done without coiding anything? just plug-n-play the new gateway? :scared:
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
Re: Rcd510 need answer asap please
« Reply #1 on: August 19, 2014, 09:22:03 pm »
The gateway needs to be coded. PM Eddie NL on this forum as he sells gateways.
'07 Red manual
Offline K9
  • VW LifeStyle
« Reply #2 on: August 19, 2014, 09:23:26 pm »
Thanks you! will do :drinking:
Offline J400uk
  • -Receive: 27
« Reply #3 on: August 19, 2014, 09:37:35 pm »
Your choice is either buy a pre-coded gateway (contact EddieNL) or buy one and code it yourself using VCDS if you have access
