Author Topic: RNS310 SatNav problem.  (Read 5718 times)
Offline matt_the_mussel
  • TV; Teacher, Mother, Secret lover.
« on: September 11, 2014, 08:23:17 pm »
Hey guys, I've just fitted my second(!) rns310. Nice little unit but on both, the nav works for about 3 miles then the whole unit resets, and keeps resetting every 30 second or so until you take the disc out....Tried another disc, same thing! I know these thing are supposed to be plug and play and don't give you a battery drain (mines a 2005 GTI) which seems to be true but maybe it does need coding? I cant believe I had 2 dodgy units!?
Offline Viking
  • -Given: 17
  • -Receive: 47
Re: RNS310 SatNav problem.
« Reply #1 on: September 11, 2014, 08:47:10 pm »
Did you have a nav unit in previously before these two? Because if you didn't then you need to tell the car you have a nav fitted.
Sarcasm for free. Anything after that can only be considered as a bonus.
Just because you think you know something, doesn't make you an expert if you've just read it on the internet, y'know.
« Reply #2 on: September 11, 2014, 09:08:34 pm »
Thanks for the reply. No, I had an RCD300. I thought it only needed to be coded if I had a highline display?
Offline Viking
  • -Given: 17
  • -Receive: 47
« Reply #3 on: September 11, 2014, 09:12:07 pm »
No, you need to code the unit as a navigation unit otherwise the car doesn't know you have nav.
Offline joolstdi
« Reply #4 on: September 11, 2014, 09:51:45 pm »
Hi viking,
where in vag com do you put in the code and what code is needed.
I have vag com and a rns310 and it keeps losing gps but radio, cd amd sd card works great.
maybe it needsa a new gps anttenna.
jools
Offline Shoduchi
  • -Given: 220
  • -Receive: 430
« Reply #5 on: September 11, 2014, 10:54:18 pm »
You might need to reposition your antenna or get a new one.
Carsystems.pl sells them pretty cheap and they're good.
Offline Viking
  • -Given: 17
  • -Receive: 47
« Reply #6 on: September 12, 2014, 06:21:59 am »
Go into VCDS > Controller 19 - CAN Gateway > Byte 4 > Bit 6 check box for navigation. Should be from memory.
Then in Controller 37 set up options for your car as required.
  • -Receive: 453
« Reply #7 on: September 13, 2014, 01:36:21 pm »
or just check the Nav check box in the installation list for the gateway...  :smiley:
Offline J400uk
  • -Receive: 27
« Reply #8 on: September 14, 2014, 12:42:22 am »
I've never had any issues with mine except when playing music in a format it doesn't like. Try copying the maps from CD to SD as that seems to improve performance.
« Reply #9 on: September 20, 2014, 10:20:31 am »
Right, I've had the gateway coded for nav and it still resets after a couple of miles. It has been suggested that I change the gateway as its a 2005 gti but I dont seem to be getting any power drain so is it really worth it?
I will try copying to SD....if it works long enough to do it!
