Author Topic: new member and owner needs help  (Read 1635 times)
Offline errorinside
« on: November 12, 2014, 07:48:51 pm »
Hi all , ive just brought a golf gti mk5  ive wanted 1 for years  and managed to find a nice fully loaded one :) I have a few questions about it  I hope this is the right place to post this .
1st ,  ive noticed when I open the door via remote on key  the drivers  door makes a  strange noise but only when I open , when I lock its fine , the noise is like a vibration sound ? make any sense ?   2nd is  the  boot handle has corroded can I fix this ? also how do you use cruse control and auto wipers ? any help would be great thanks
Re: new member and owner needs help
« Reply #1 on: November 12, 2014, 07:57:20 pm »
Hello and welcome to the forum
1.the noise when you open the door will be the door module i would think it making the noise you mention
2.take it your gti is a early one with the white worm,you can either paint it like i did or replace it with a later badge
3: cruise control works over 60 mph i thing and you should have a slide switch on the indicator stalk
Offline Shoduchi
  • -Given: 220
  • -Receive: 430
« Reply #2 on: November 12, 2014, 08:04:22 pm »
My cruise control works for whatever speed I select or currently going. :confused:
I press the left button of the left stalk to activate and turn the upper button to the right to deactivate.
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #3 on: November 12, 2014, 08:10:54 pm »
Welcome to the forum.
Cruise normally works around the 15mph mark think.
« Reply #4 on: November 12, 2014, 08:47:50 pm »
will have to try that
