Author Topic: Highline Cluster Upgrade Info and FAQ's  (Read 68776 times)
Offline Ben_VTR
Re: Highline Cluster Upgrade Info and FAQ's
« Reply #45 on: August 17, 2017, 05:41:49 pm »
How are you accessing the menu mij? By holding the wiper rocker button or menu button on sw?
I think if it was factory fitted with a 973, then it can work off rocker switch (like mine) but then i switched to a mfsw and it now works off sw menu button
Sent from my SM-G955F using Tapatalk
Hey bud. I understand I wouldn't be able to go through the menus (until I got a MFSW and module installed), but would the clocks actually work okay, and let me go through the normal trip options? (MPG, fuel range etc). Then I could at least get these clocks while they are cheap, get them in and then in a few months time when I can afford a wheel, get it put in and then use the menus?
Thing is I need to get new clocks soon as my current ones are playing up (random lights come on that shouldn't when I indicate, have the handbrake on or use cruise control, so would be an MOT fail. Hence the need for new ones.
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #46 on: August 17, 2017, 05:53:27 pm »
Yep you will be ok
Offline shoaybmakda
  • -Receive: 54
« Reply #47 on: August 17, 2017, 08:23:05 pm »
I’ll have some highlines clocks for sale this weekend
Offline phas3r
« Reply #48 on: December 02, 2017, 04:28:42 pm »
Hi,
I am looking at a 972 hi line cluster on ebay.
My car is mid line 2008 GTI, with MFSW, retrofitted cruise stalk. The car is not in the UK, but I myself will be there for another few weeks.
Am I able to fit it in, as according to the first post I need to refer to VW specialist to get the SKC Code ?
08 MKV GTI DSG shadow blue
Engine: Revo Stage 2 7-3-9 | Forge Twintake | S3 Intercooler | R8 Coils | APR RSC MK6 Catback + 3" DeCat Downpipe
Brake/Susp : Golf R 345mm Front | Michelin PS4 225/40/18 | BBS CO VZ033 18" | H&R Rear ARB | S3 Lower Arm Bush
Interior: RNS 510 | 9WZ | Retrofitted CC | MK6R Rev Cam | Midline cluster :(
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #49 on: December 03, 2017, 11:09:49 pm »
Hi,
2008 will have to be done by a specialist. Its not just about getting the skc, it's also about getting the keys matched up as well.
Best to contact Alex (Olsen-72), Usual suspect or Eddie-NL if you're lucky.
johnbanana
« Reply #50 on: February 14, 2019, 04:32:09 pm »
Hi guys,
i'm wondering if i will be able to go through menu on highline cluster 872? Year of cluster is 2006, i have a stalk with rocker buttons but i don't have MFSW
Offline Mark22
« Reply #51 on: June 19, 2019, 12:47:40 pm »
Hi, im new here so can send pm, i need help with instrument cluster ending 974. Or can OLSEN-72 contact please.
Offline olsen-72
  • -Receive: 21
  • Redditch
« Reply #52 on: June 20, 2019, 03:48:14 pm »
What you after mate?
STAGING/NEEDLE SWEEP ON ALL WHITE CLOCKS
LIT NEEDLESS, MILES TO EMPTY
GENUINE CAN GATEWAY - SUPPLY AND FIT
CRUISE CONTROL -  SUPPLY AND FIT ALL VW's
CLOCKS CODING - VW SEAT SKODA UP TO 2014
SCIROCCO CLOCKS CONVERSION
Offline Mark22
« Reply #53 on: June 23, 2019, 04:59:25 pm »
i think i already contacted you trough email ;) northern ireland ;)
Offline Mark22
« Reply #54 on: June 25, 2019, 10:20:30 pm »
olsen 72, man of the year!!!! if yous need any help, ask him, he will help you in any way!
Offline NitrousOxide
« Reply #55 on: January 23, 2020, 11:08:59 pm »
Highline - This cluster is the expert level. As well as the above, it will show you an image of your car to show which doors are open, setup menu, Audio, navigation, phone.(Additional parts may be needed for eg RNS 510)
These will come in part numbers ending 970,971,972,973,974
I recently acquired a MK6 Golf cluter that I am about to retroft in my 2008 MK5 GTI that already has a highline cluster, MFSW, and DSG.
The MK6 cluster has the part number 5K6-920-972-E.  I just wanted to verify that the 972 numbering convention still means that I have a highline cluster, before I do the immobilizer work seen in other forums.
Offline olsen-72
  • -Receive: 21
  • Redditch
« Reply #56 on: January 24, 2020, 08:21:35 am »
Yes its highline cluster
Offline Ben_VTR
« Reply #57 on: February 12, 2020, 09:57:18 am »
Hi all.
So, eventually bought a set of 973 clusters for my late 2007 Jetta. Also bought an RCD330, and a newer style MFSW.
Was told I needed a control module, part number 1K0 953 549 CH, so bought that.
Left it all to get fitted at a local specialist, MFSW and paddles work, buttons working with the Head unit etc, but now my cruise control won’t work? Will I need a new stalk or control module? Or is there something missed?
Offline olsen-72
  • -Receive: 21
  • Redditch
« Reply #58 on: February 12, 2020, 10:34:53 am »
New stalk or modify your current stalk wiring
Offline Ben_VTR
« Reply #59 on: February 12, 2020, 11:35:19 am »
Ta! Would you be able to advise what part number stalk I’d need? Or would you need the current stalk’s part number to know?
By modify the wiring, is there a guide or is this trial and error? Lol
