Author Topic: Few rns 510 issues  (Read 4492 times)
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Few rns 510 issues
« on: December 14, 2014, 11:06:22 am »
Hi all. Fitted an rns 510 yesterday, coded it and it doesn't pick up on my highline cluster.
Also I noticed my fiscon basic plus sounds terrible on the rns! It was perfect on the rcd300.
Any ideas peeps?
Offline DamoP
  • -Receive: 115
  • 2007 Edition 30 number 1242
Re: Few rns 510 issues
« Reply #1 on: December 14, 2014, 11:28:48 am »
my first port of call would be check the firmware, then any errors in vagcom?
MDI Armrest & Glovebox kits
Armrests, cloth and leather
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #2 on: December 14, 2014, 12:48:16 pm »
I put 3810 on it to prevent battery drain. Used it before. With no problems
Offline Shoduchi
  • -Given: 220
  • -Receive: 430
« Reply #3 on: December 14, 2014, 01:09:44 pm »
For what I know FW3810 won't prevent battery drain unless it was modified and for that option you can install newer firmwares and then install the patch to prevent battery drain.
Are you sure you ticked off the BAP protocol?
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #4 on: December 14, 2014, 02:13:01 pm »
Its already modified.  Good call, ill check the bap box.
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #5 on: December 14, 2014, 09:18:17 pm »
Unticked bap and now nav and music shows in highline display.  Thanks bud.
Anyone know why the a2dp and calls on the fiscon basic plus is so low?
Offline skard
  • -Receive: 245
« Reply #6 on: December 14, 2014, 09:23:19 pm »
I had this with my old Fiscon, basically by wiggling about the loom it picked up in volume. In the end I found out what strand was causing it and had to cable tie it back to keep it from wiggling about. Worked fine thereafter.
Kufatec's QC isn't all that great at times
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #7 on: December 14, 2014, 09:29:34 pm »
I tried wiggling the loom at the quad connector end and no difference. .ill try on the module end and see. Strange though it was fine on the rcd300. Ill try plugging that in as well and see how it sounds.
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #8 on: December 18, 2014, 07:05:52 pm »
Ok I plugged in my rcd300 back in and the sound quality is clear as it should be. Something on the rns 510 doesnt like the fiscon unit. Any ideas anyone?  Im on 3810 modified firmware to prevent battery drain.
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #9 on: December 20, 2014, 01:24:24 pm »
tried the pin swap as suggested by a fellow member but still sounds terrible on a2dp and phone calls.
Anyone have any other suggestions?
Offline skard
  • -Receive: 245
« Reply #10 on: December 20, 2014, 01:41:41 pm »
There are some codes you dial in to change Fiscon settings such as switch between mono and stereo, should be on the manual on Kufatec site
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #11 on: December 20, 2014, 09:31:01 pm »
Hi skard
I've tried that too but no luck :(
Offline Shoduchi
  • -Given: 220
  • -Receive: 430
« Reply #12 on: December 20, 2014, 09:35:28 pm »
I'd try contacting Kufatec after all your attempts to solve this. Since your radio sounds good it seems the problem is from the Fiscon. :confused:
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #13 on: January 17, 2015, 04:16:24 pm »
this has now been sorted. was a coding issue.
« Last Edit: January 17, 2015, 08:55:39 pm by vw55raz »
Offline Shoduchi
  • -Given: 220
  • -Receive: 430
« Reply #14 on: January 17, 2015, 08:21:28 pm »
Nice. Cheap solution. :smiley:
