Author Topic: New car, a4 Quattro special edition  (Read 16545 times)
Re: New car, a4 Quattro special edition
« Reply #30 on: January 30, 2015, 12:40:30 am »
wow looks excellent
Offline cuprajake
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,72567.0.html
« Reply #31 on: January 30, 2015, 10:31:51 pm »
Strange day today,
Went and rescued my dad who has been snowed in, for summer tyres the quattro is very good.
IMAG3998 by cuprajake1, on Flickr
And at the summit
IMAG3994 by cuprajake1, on Flickr
After we had returned from hunting (big shop) I got chance to mess with my wheels
In the booth prepped and clean
IMAG4002 by cuprajake1, on Flickr
Then ground coat black
IMAG4005 by cuprajake1, on Flickr
Then on with silver followed by clear coat
IMAG4009 by cuprajake1, on Flickr
IMAG4010 by cuprajake1, on Flickr
Tomorrow it will be polish the other three lips then clean the insides as once the wheels are rebuilt they will need balancing.
Jake
Tornado red ed30 #0728
Offline Powervalve Nige
  • Trader - 2014
  • -Given: 84
  • -Receive: 76
    • POWERVALVE
« Reply #32 on: January 31, 2015, 04:06:07 pm »
Awesome Jake  :happy2:
Offline cuprajake
« Reply #33 on: January 31, 2015, 08:32:14 pm »
Cheers Nige.
Do you offer any systems for these cars? It's in need of a bit more sound.
Did a bit more on the wheels today,
Sanded the barrels as they were corroded, then put into the booth for primer then paint, went for a gun metal finish inside
IMAG4013 by cuprajake1, on Flickr
IMAG4017 by cuprajake1, on Flickr
IMAG4019 by cuprajake1, on Flickr
Did the centre caps too
IMAG4016 by cuprajake1, on Flickr
Here are the centres out of the booth in day light
IMAG4023 by cuprajake1, on Flickr
Then this aft had a oem Bluetooth module fitted and coded. It's really surprising how much you miss them
Jake
Offline ed30sam123
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,88570.0.html
« Reply #34 on: February 01, 2015, 04:19:48 pm »
very nice Jake  :happy2:
Tornado red ED30 No. 0728
Offline cuprajake
« Reply #35 on: February 02, 2015, 05:37:47 pm »
one thing that has slightly bugged/worried me is the car feels quite notchy on the gear change, hard to get into first and second, well today I changed my gearbox oil, which made a slight improvement nothing drastic, so I used a guide on fine adjustment of the linkage,
what the guide doesn't show is how to get to it so:
take the gear lever off, stupid clip.. I replaced the metal clip with a hose clip after,
then you have to pull the foam out, and the ashtray with 2 8mm bolts,
push the ashtray back, there's some rubber matting, fold that back, and under it a plastic cover with 2 10mm bolts,
undo these and then you can see the linkage,
use this vid
its made a massive difference,
ive also found a few little niggles to sort to keep me busy haha
Offline cuprajake
« Reply #36 on: February 03, 2015, 06:25:52 pm »
Hey guys
This is the oil I used, all genuine stuff from audi, fortune.
Diff and gearbox
IMAG4024 by cuprajake1, on Flickr
Then I set about my heated passat washer jets, now the guides say that you have to glue these in place, which is pants and you don't
There are tabs front and back which are straight along the edge, take a soldering iron and heat the tab, then bend it forward, the heat stops it breaking,
IMAG4035 by cuprajake1, on Flickr
IMAG4036 by cuprajake1, on Flickr
Then when you fit it to the car simply put the back in first then the tabs you've bent can be pushed in to hold the washer jet in place
Then finally I built the wheels up, torqued to 26ftlb and then tomorrow ill be getting them balanced
IMAG4048 by cuprajake1, on Flickr
Jake
Offline cuprajake
« Reply #37 on: February 04, 2015, 06:29:34 pm »
Well cars been a pita today,
Dropped the little lad off at nursery and the remote locking wont work, so change the battery and go through the rest procedure. And nothing, so using vagcom I clear the keys and then go to recode but the car won't recognise the key when the buttons pressed, at home I code the other key fine, so I'm now left wondering if the fob is a dud.
On a better note I've ordered 5mm front spacers and 15mm rear both hubbcentric with longer bolts and lockers, unforeseen but not too bad.
Jake
Offline GTiBlues
  • Mr Blues
    • Bookface
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,75444.0.html
« Reply #38 on: February 05, 2015, 07:04:33 pm »
Sounds a good touch with spacers. As for your fob, my guess it'll be the fob too? my old Leon had the same issue.
Offline jaffa
  • -Receive: 44
« Reply #39 on: February 05, 2015, 07:15:03 pm »
i thought i recognised those wheels they were lammy's weren't they?
some nice touches to the car makes a big difference
Offline cuprajake
« Reply #40 on: February 06, 2015, 06:34:30 am »
The spacers arrived just after lunch
So chucked the wheels on,
Tbh could of got away with 10 on the front and maybe 20 on the rear lol
They really suit the car,  so happy with them.
My kufatech harnesses came too so the Xenons will go in on Sat.
Then just a few minor bits like the foot well lights and door lights to fit.
Also got the remote locking working on the fob again.
Jake
Offline cuprajake
« Reply #41 on: February 06, 2015, 08:53:40 pm »
Fitted the lights at dinner
Bumper off jobbie
Then back together
Still need to do the two repair wires but the lights have coded in ok.
One how ever is yellowing. So hope it's just the bulb, not ballast. More honest eBay sellers.
Offline doylebros
  • -Receive: 310
« Reply #42 on: February 06, 2015, 08:59:47 pm »
Bumper off jobbie
Then back together
Is it just me but I can't see the photos it's just black?
Offline cuprajake
« Reply #43 on: February 06, 2015, 09:39:24 pm »
IMAG4066 by cuprajake1, on Flickr
IMAG4070 by cuprajake1, on Flickr
Offline doylebros
  • -Receive: 310
« Reply #44 on: February 06, 2015, 09:45:07 pm »
No problem with the photos now - good progress being made
