Author Topic: Adding TPMS to new alloys  (Read 1434 times)
Offline SiofChester
« on: January 19, 2015, 04:30:23 pm »
So I've got a new set of wheels on their way to me, genuine 17" Monzas which I shall have refurbed... The current wheels have the tyre pressure monitoring in them and I'd like to duplicate this on the new rims but not sure what I need to do to get it working. Anyone done this, is it just a case of get a new set of appropriate valves and everything will be picked up, or do I need to "pair" the valves to the car???
Anyone got a source for cheap TPMS valves?
Offline simonp
  • -Receive: 38
  • No longer a Golfer
Re: Adding TPMS to new alloys
« Reply #1 on: January 19, 2015, 04:39:36 pm »
If it's the standard fit tyre monitoring then you don't have to do anything, just reset it when the other wheels are fitted. If it's aftermarket then you'll need new sensors. The standard fit just uses the ABS sensors to detect wheel rpms. If one is spinning at a different speed then it assumes that wheel has a lower pressure than the others...
Offline olsen-72
  • -Receive: 21
  • Redditch
« Reply #2 on: January 19, 2015, 05:02:09 pm »
His system is different. You talking about TPMS Low. His is High.
You will nee wiring and a small module fitted outside, near rear axle
STAGING/NEEDLE SWEEP ON ALL WHITE CLOCKS
LIT NEEDLESS, MILES TO EMPTY
GENUINE CAN GATEWAY - SUPPLY AND FIT
CRUISE CONTROL -  SUPPLY AND FIT ALL VW's
CLOCKS CODING - VW SEAT SKODA UP TO 2014
SCIROCCO CLOCKS CONVERSION
