Author Topic: How to turn on Auto windscreen wipers?  (Read 8065 times)
Offline Sav213
« on: January 21, 2015, 10:23:44 am »
Hi
Just wondering if i have to do soemthing to turn on auto windscreen wipers on my GTi? Not sure if i there's a mode to put it in or if it does it by itself?
Offline skard
  • -Receive: 245
Re: How to turn on Auto windscreen wipers?
« Reply #1 on: January 21, 2015, 10:29:07 am »
Flick your wiper stalk up one notch, then use the top switch to adjust the sensitivity of the sensor.
It seems to need reset every time you get back in the car.
Offline Sav213
« Reply #2 on: January 21, 2015, 10:37:25 am »
So is this the setting for only when it rains they will activate? Not what you get on normal 'auto' windsreen car's
Do all MK5 gti 07- have auto windscreen wipers sensor's?
Offline skard
  • -Receive: 245
« Reply #3 on: January 21, 2015, 11:22:05 am »
Al UK spec GTI's have it, it is a box behind your interior mirror. The sensor is inside a metal frame bonded to the window.
Offline Golfgirl
« Reply #4 on: January 21, 2015, 11:30:11 am »
A word of warning - they're rubbish! :confused:  They wipe when they don't need to and don't wipe when you have water on the screen! :fighting:
FOR SALE!
Offline mvb12
  • -Receive: 64
« Reply #5 on: January 21, 2015, 02:11:10 pm »
mine works how it should.....
Offline xjay1337
  • -Receive: 377
« Reply #6 on: January 21, 2015, 02:36:40 pm »
3 Mk5 platform cars now and they all have worked wonderfully  :booty:
Offline KieranR
« Reply #7 on: January 21, 2015, 03:56:13 pm »
Mine is not great either. When I get in the car there could be water on the screen and I have to flick the little switch to get them going.   Saying that I scanned the car with vcds and it said I have an intermittent fault with the controller stalk so will replace it when I'm adding cruise
dansmith180
« Reply #8 on: January 21, 2015, 04:15:19 pm »
I find mine very annoying as well, particularly at lower speeds / lighter rain they can't get it right. I quite often resort to just flicking the stalk down when I want them done.
Offline Matthewsimone
  • -Receive: 39
« Reply #9 on: January 21, 2015, 05:00:46 pm »
Mine works perfectly on both our mk5's, you think the auto wipers are bad on vw try a Renault  :sick: and the reason why they reset everytime you get back in the car and start engine is because you wouldn't want the auto wiper to kick straight in on a cold morning over a frosty screen now would you otherwise you would need to remember to turn auto mode off everytime you got out of the car  :congrats: clever little system, good old vw thought of everything
Offline reaper7881
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,68492
« Reply #10 on: January 21, 2015, 05:37:16 pm »
you can adjust the sensitivity in vagcom  and enable rain closing if u have the right modules
54 MK5 Golf 1.9tdi 3dr SMD Full Interior and Speedo Conversion, GTi Highline , Flat Bottom Wheel, ED30 Rear lights
