Author Topic: Changing from mfd2 to mfd3  (Read 1699 times)
Offline Its Dave
« on: January 26, 2015, 12:44:06 pm »
Sorry really new to this just picked up a gold edition 30 and want to link my iPhone 6 up and also play music from iPhone
So looking for a rcd500 do I get on dab or not?
Also will I need to change canbus?
Damian got a kit for sale so can link up phone so think that's all l might need?
Dave
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
Re: Changing from mfd2 to mfd3
« Reply #1 on: January 26, 2015, 01:01:03 pm »
Hi Dave,
Do you mean you want to upgrade from the MFD2 which is a Satnav unit to the MFD3 which is the RNS510 satnav that comes with Dab also?
If you want link your iPhone to a RCD510 or RNS510, both of which can come with DAB there are a couple of options, the cheapest is the RCD510 DAB.
Offline Its Dave
« Reply #2 on: January 26, 2015, 01:17:03 pm »
Hi Dave,
Yes that's what l want to do
Take it will need to change canbus? Battery drain issues?
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
« Reply #3 on: January 26, 2015, 01:27:22 pm »
Using an RCD510 non DAB as example of approx. costs
£180 RCD510 Headunit
£70   Gateway
£10   FM aerial adapter
You then have three options for connecting your iphone. Based on you want to play music only.
1- £10.00 Aux input installed next to the gearstick (or)
2- £200.00 MDI installed in either the armrest or glovebox (or)
3- £150.00 For 7P6 Bluetooth adapter to stream music by Bluetooth but you'll only get Mono.
You will need to find somebody with VCDS to code the gateway or failing that EDDIE-NL will be able to provide you with a pre coded gateway.
