Author Topic: rear wheel bearing  (Read 2256 times)
Offline Danbear79
rear wheel bearing
« on: January 27, 2015, 05:41:52 pm »
Anyone know the size of the rear wheel bearing on an 05 Gti? Apparently there's 2 options. Also is a straight forward job?
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
Re: rear wheel bearing
« Reply #1 on: January 28, 2015, 08:58:50 am »
Didn't know this, two sizes, but our US versions usually differ.
This is what I replaced mine with: http://www.urotuning.com/ProductDetails.asp?ProductCode=1K0598611
It is quite easy to do, yes. You will need some extra leverage when loosening the hub bolts. And the torque when tightening is stated to be 132 lb*ft plus 180 degrees...so you torque it and use your leverage to go another 180 degrees. Use new bolts...so if your hubs come without them...get them.
http://workshop-manuals.com/volkswagen/golf-mk5/running_gear_axles_steering/rear_suspension_drive_shaft/assembly_overview_wheel_bearing_housing_trailing_arm_%28front-wheel_drive%29/removing_and_installing_wheel_bearing/wheel_hub_unit/
Offline Danbear79
« Reply #2 on: January 28, 2015, 06:01:23 pm »
Thanks much :) when I went to order online I had a choice of 30mm and 32mm. so many options on cars nowadays
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
« Reply #3 on: January 29, 2015, 07:56:37 pm »
There may be a difference due to model...GTI, Edition 30, and R32. Somewhere in that may be a 30mm and 32mm. Can you reference it by part number?
