Author Topic: Mk6 gti clocks with white display onto mk5?  (Read 15225 times)
Offline jedi-knight83
  • -Receive: 41
« on: February 02, 2015, 01:54:38 pm »
Just wondering if it's a straight swap and with the right coding / modules it was an easy swap. After spending so much time in my new 2012 caddy with the White display the red one in the gold now looks pretty out dated.
Would be nice to get he proper Bluetooth menu aswell.
Offline skard
  • -Receive: 245
Re: Mk6 gti clocks with white display onto mk5?
« Reply #1 on: February 02, 2015, 01:56:34 pm »
Yes but you will need a new ABS pump, two key chips, conversion loom and a recent CAN gateway.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #2 on: February 02, 2015, 01:56:56 pm »
Cluster and Key coding
Location Great Yarmouth
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #3 on: February 02, 2015, 01:57:40 pm »
ABS needs to be a Q or higher
Offline skard
  • -Receive: 245
« Reply #4 on: February 02, 2015, 02:04:51 pm »
Talk to Ed, he did my Tiguan  :happy2:
Offline GTi-Andy
« Reply #5 on: February 02, 2015, 02:59:25 pm »
another vote for Ed, he did mine too!
So much for keeping it standard!
  • -Receive: 41
« Reply #6 on: February 02, 2015, 03:07:41 pm »
Cool. I'll check my abs when I'm back home at the weekend. If that's not compatible I'm not going to mess about changing that.
Presuming that is compatible how much are we talking roughly. To fit to a 2005 gti dsg. Would want the full highline with Bluetooth support.
Offline SI-R32
  • -Receive: 126
« Reply #7 on: February 02, 2015, 03:23:15 pm »
not to deflate you to much but as you've just said a 2005 i'd have to say right now that your ABS unit will be to old, approx 57 onward was the the correct one fitted.
  • -Receive: 41
« Reply #8 on: February 02, 2015, 03:49:28 pm »
Balls. So no other way of getting white display.
Offline skard
  • -Receive: 245
« Reply #9 on: February 02, 2015, 03:52:02 pm »
It's just another expense, totally do-able otherwise
Offline GTi-Andy
« Reply #10 on: February 02, 2015, 03:52:18 pm »
SMD change from blue to white, As an alternative?
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #11 on: February 02, 2015, 04:16:58 pm »
check your abs pump before you do anything else
you might be ok, late 2005 car will be a 2006 model year at the factory
Offline doylebros
  • -Receive: 310
« Reply #12 on: February 02, 2015, 06:15:48 pm »
The ABS pump as a replacement item isn't much of a job start to finish including bleeding two hours and no ramp needed!
Offline olsen-72
  • -Receive: 21
  • Redditch
« Reply #13 on: February 02, 2015, 06:20:35 pm »
N
Not really. 3 weeks ago I fitted 05 plate golf with white clocks without changing abs pump
« Last Edit: February 02, 2015, 06:22:52 pm by olsen-72 »
STAGING/NEEDLE SWEEP ON ALL WHITE CLOCKS
LIT NEEDLESS, MILES TO EMPTY
GENUINE CAN GATEWAY - SUPPLY AND FIT
CRUISE CONTROL -  SUPPLY AND FIT ALL VW's
CLOCKS CODING - VW SEAT SKODA UP TO 2014
SCIROCCO CLOCKS CONVERSION
Offline SI-R32
  • -Receive: 126
« Reply #14 on: February 02, 2015, 09:22:57 pm »
@olsen-72 did you have any ABS fault codes after you changed these clocks? Any chance you saved a scan of his car to see the ABS part number?
