Author Topic: Somebody please help! Clutch, flywheel, LSD problems.  (Read 1787 times)
Offline GTI44
« on: February 06, 2015, 10:48:55 pm »
Hello guys, I need some help with my 2005 MK5 GTI.
Before Christmas I bought a nearly new Helix clutch and single mass flywheel (used for 3k and supplied and removed by AKS tuning) and a second hand box with Quaife ATB LSD already installed. I got these fitted and within 500 metres I knew it wasn't right. The car is standard otherwise.
The diff was definitely working but on deceleration / overrun there was a loud sort of grinding noise. It was noticeably louder at higher revs and got a bit louder as the engine warmed up. It happened in every gear but disappeared as soon as you dipped the clutch. I think it may do it on acceleration too but it is much quieter if it is.
After speaking to a few people I had the box taken off again and took it to a local gearbox specialist. He said the diff looked fine but a few gears were worn so he replaced these (by canabalizing the original box) and did a general overhaul / refurb replacing anything that looked tired.
Anyway, I had the box fitted again today with new OEM box oil (recommend by Quaife). So I picked the car up again tonight, and it is exactly the same!
I just don't know what to do, and no one in my area seems to be able to sort it and it is costing a fortune in labour, oil etc.
Does anybody have any ideas or recommendations!?
Any help very much appreciated  :sad1:
Cheers!
Offline rubber toe
Re: Somebody please help! Clutch, flywheel, LSD problems.
« Reply #1 on: February 06, 2015, 11:18:18 pm »
Did you have a new release bearing fitted ?? I can only assume someone has checked it since the box has been removed , are you taking into account the added noises you get when going smf?
Offline GTI44
« Reply #2 on: February 06, 2015, 11:29:50 pm »
Thanks for the reply mate, yes I had a new one before fitting. To be honest it's the first SMF I've had, but know a few people who have had them in the past and dont remember it being anything like this. Would a SMF be pretty loud on overun? It is a very metal on metal type noise.
Offline cooljimy84
    • Personal
« Reply #3 on: February 07, 2015, 12:18:18 am »
Like a straight cut gaerbox ? I've only heard them on old Mimi's and they sound wrong/broken but is perfectly normal...
Might be worth utubeing a video so ppl can hear
There is no replacement for displacement....
But a turbo does help....
Offline jasam
  • My Ride: 2.0 tfsi k04, revo stage 3
« Reply #4 on: February 18, 2015, 12:03:01 pm »
Hi mate, did you sort noise problem on gearbox?
I have same problem, also helix clutch and single mass flywheel
Offline Pikey Motorsports
« Reply #5 on: February 18, 2015, 12:31:58 pm »
Possibly the clutch all smf clutches I have used do it
How much did the box rebuild cost out of interest
TSR PERFORMANCE GTX30 520BHP
LITCHFIELD R35 GT-R 660BHP
MSL E63 AMG 720BHP
HCP BM3 M5 800BHP
Offline jasam
« Reply #6 on: February 18, 2015, 04:46:12 pm »
was that sound same as mine?
here:
Offline MJGib
  • -Given: 22
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,85702
« Reply #7 on: February 18, 2015, 05:13:55 pm »
It's proberly the SMF they cause vibrations
Or the only other thing I can suggest is the bearings (internally)
MK5 Golf GTI: K04 converted stage 2+ (I don't own this car no more)
Insta - gibs94_
Offline Dallen75
« Reply #8 on: February 18, 2015, 08:45:58 pm »
Its your SMF mate its called chattering and one minute it can be fairly quiet, the next rather loud, ive got a loba sachs setup mine does it too
Offline GTI44
« Reply #9 on: February 18, 2015, 09:50:03 pm »
It was £288 mate - I know some parts were new, others were re-cycled from my other (good) box
Offline GTI44
« Reply #10 on: February 18, 2015, 09:53:51 pm »
here:
I can't really hear for that mate (over the intake) but to be honest I tried to video mine and it dIdnt really record very loud at all
Offline GTI44
« Reply #11 on: February 18, 2015, 09:55:38 pm »
Thanks mate, at high revs it's always loud (very loud!) but at low revs and idle it can be worse sometimes than others. I still think it's worse than it should be as everyone getting in the car thinks the engines about to blow up haha but it does reassure me a little!
